bbqen2 Posted November 30, 2004 Report Posted November 30, 2004 I've got a 93 lumina (bought used). I've read enough posts to know the "pump to set" is correct, but some of you guys have an e brake lite. My car never has. Is it suppose too? Quote
Regal_GS_1989 Posted December 1, 2004 Report Posted December 1, 2004 All W's have an E-brake light. Maybe yours is just burnt out, or the switch to activate is is shot. Quote
bbqen2 Posted December 1, 2004 Author Report Posted December 1, 2004 Thanks. I thought it was a pretty shitty design, not to have one. I just got ahold of the local GM dealer and had them order me a service manual. Quote
Robby1870 Posted December 1, 2004 Report Posted December 1, 2004 I bet the bulb is burned out. Just take the cluster out and replace it Quote
bbqen2 Posted December 1, 2004 Author Report Posted December 1, 2004 We bought the car with 19,000 miles on it and it didn't have a E brake light then. Might sound stupid but I didn't think GM put one in. Quote
Justin Posted December 1, 2004 Report Posted December 1, 2004 I'd bet the switch was bad, keeping the light on. More than likely they just unplugged the switch, like I did. Look down there for a single wire switch on the e-brake mechanism and see if it's hooked up. Quote
Jcrow Posted December 1, 2004 Report Posted December 1, 2004 my switch is corroded and the light dosen't work Quote
White93z34 Posted December 1, 2004 Report Posted December 1, 2004 We bought the car with 19,000 miles on it and it didn't have a E brake light then. Might sound stupid but I didn't think GM put one in. test the switch and bulb, one thing i learned is that older gm cars don't mind eating lightbulbs at all EDIT: just went out and looked at my car if it has the gauges with the Tach, when you turn the car on the light that says "BRAKE" right under the 10mph on the speedo should light for a split second then go out, if it never flashes then the bulbs bad, if it does flash the switch is the culpret Quote
bbqen2 Posted December 4, 2004 Author Report Posted December 4, 2004 it is the switch that was bad. It wasn't making contact when the e brake was applied. Thanks for your help Quote
