cutlsp Posted February 26, 2005 Report Posted February 26, 2005 i found a set of them i didn't know they were going to cost around 30 bucks. oh well i guess i need them because i noticed the rubber is really worn out i stuck some blocks of wood in the slots and what'd ya know the rear end became higher then the front like its suppose to look Quote
Robby1870 Posted February 26, 2005 Report Posted February 26, 2005 Thanks guys, that helps me a ton. Quote
cutlsp Posted February 27, 2005 Report Posted February 27, 2005 Thanks guys, that helps me a ton. it kinda helps me too but i can't afford the poly pucks right now. Quote
Givemebreak Posted February 27, 2005 Report Posted February 27, 2005 NP guys... cutlsp...I paid $16 and change for mine? 30 seems high? Quote
cutlsp Posted February 27, 2005 Report Posted February 27, 2005 where can i get them from hit me up on aim if you can :? Quote
Givemebreak Posted February 27, 2005 Report Posted February 27, 2005 http://froogle.google.com/froogle_url?q=http://www.rockauto.com/catalog/catalog.php%3Fcatalog%3D11%26partnum%3DK6544%26a%3DFR11-K6544&fr=APvR3Gjdwk5DDk_P10vI-he4xwWlAWUJwsW1qVepQjALAAAAAAAAAAA Quote
supreme_style21 Posted February 27, 2005 Report Posted February 27, 2005 I do know the ribs face down and the little nubs slide in between the metal to lock them in. You put the open end up, so the leaf sits in it, IIRC. Otherwise, I can see the ass-end sitting 2 inches higher. Quote
cutlsp Posted February 27, 2005 Report Posted February 27, 2005 I do know the ribs face down and the little nubs slide in between the metal to lock them in. You put the open end up, so the leaf sits in it, IIRC. Otherwise, I can see the ass-end sitting 2 inches higher. i see no problem with the ass sitting 2 inches higher it sags right now i would rather have it higher up then sagging like a pos. Quote
Givemebreak Posted February 28, 2005 Report Posted February 28, 2005 I do know the ribs face down and the little nubs slide in between the metal to lock them in. You put the open end up, so the leaf sits in it, IIRC. Otherwise, I can see the ass-end sitting 2 inches higher. There is a flat side and a ribbed side....the flat side goes up and it is labeled TOP. The spring needs that flat surface to ride along when the spring compresses. Quote
Stealth Posted February 28, 2005 Report Posted February 28, 2005 I do know the ribs face down and the little nubs slide in between the metal to lock them in. You put the open end up, so the leaf sits in it, IIRC. Otherwise, I can see the ass-end sitting 2 inches higher. There is a flat side and a ribbed side....the flat side goes up and it is labeled TOP. The spring needs that flat surface to ride along when the spring compresses. uhh you sure I put mine in with the 3 slots facing up, mine didnt say anything on them, I put them in about 3 months ago Quote
OldsmoBeast Posted February 28, 2005 Author Report Posted February 28, 2005 really???? are you sure there still there??? they go in with the lips facing down so they stay in place Yeah Davis is right, and thats what NAPA told me...The lips actually do hold them in place quite well...try them the other way around!! Quote
supreme_style21 Posted February 28, 2005 Report Posted February 28, 2005 Well I put them in with the open side facing up, so the spring sat in the groove. I don't recall either side being marked 'up' nor can I see the thing coming out on its own will. The pressure of the spring in the first notch kept it in place just fine. And even with the strut fully extended, the spring still keeps contact with the knuckle. If it did come out, I think you've got bigger things to worry about. Quote
cutlsp Posted February 28, 2005 Report Posted February 28, 2005 some pics of these poly pucks would help since i got my car running today but can't drive the damn thing till i get these things taken care of :dammit: Quote
supreme_style21 Posted February 28, 2005 Report Posted February 28, 2005 some pics of these poly pucks would help http://www.federal-mogul.com/fmeconnect/technicalservices/downloads/2022.pdf Quote
Givemebreak Posted February 28, 2005 Report Posted February 28, 2005 some pics of these poly pucks would help http://www.federal-mogul.com/fmeconnect/technicalservices/downloads/2022.pdf As quoted...the pdf file has the picture and states flat side it TOP.... Ribbed up is incorrect. Quote
supreme_style21 Posted February 28, 2005 Report Posted February 28, 2005 some pics of these poly pucks would help http://www.federal-mogul.com/fmeconnect/technicalservices/downloads/2022.pdf As quoted...the pdf file has the picture and states flat side it TOP.... Ribbed up is incorrect. I see that.. I still don't see how it would make a difference. Quote
Brian P Posted February 28, 2005 Report Posted February 28, 2005 The difference is rather than the spring edge sliding along the puck, the puck is now sliding along the steel knuckle, which might create noise if not now, then down the road. Quote
supreme_style21 Posted February 28, 2005 Report Posted February 28, 2005 Makes sense... I guess that'll be someone else's headache now. Quote
Givemebreak Posted March 1, 2005 Report Posted March 1, 2005 If the puck is installed correctly, it is not possible for the puck to slide on the knuckle. The nubs on the puck lock into place inbetween the knuckle. The spring will then slide smoothly along the flat of the puck that is facing up. Before the puck the spring was sliding on the metal knucke. Quote
