jjs316 Posted November 27, 2004 Report Posted November 27, 2004 Did they make and changes over the years of 97-02 in the GTPs? Quote
Goph Posted November 27, 2004 Report Posted November 27, 2004 i do believe that they added some power but only like 10HP and I'm sure there are some other things. Quote
dbtk2 Posted November 27, 2004 Report Posted November 27, 2004 There was no power increases/decreases over the years in the GTP's. However, there were a lot of small differences in the cars. This should tell you pretty much everything you need to know. http://www.zzperformance.com/zzp/info/info_model_changes.htm Shawn Quote
EurosportZ34 Posted November 27, 2004 Report Posted November 27, 2004 wow...i never knew so much was changed on them before i read that. i thought they were all pretty much the exact same until the 2004 models. i could have missed this when reading...but what year was it that the front end of the SE's changed to that of the GT's? Quote
jjs316 Posted November 27, 2004 Author Report Posted November 27, 2004 What is the performance shift thing? and whyd they stop it on the 01s? Quote
1990lumina Posted November 28, 2004 Report Posted November 28, 2004 I'm guessing the performance shift would be like my friend's Bonneville SSEi has. You can choose between performance and normal.. according to him it has little difference though he said when on performance it has better more positive shift points after the super charger kicks in. Quote
SleeperRed90TGp Posted November 28, 2004 Report Posted November 28, 2004 97's are older. Yea they really are. Quote
dbtk2 Posted November 28, 2004 Report Posted November 28, 2004 What is the performance shift thing? and whyd they stop it on the 01s? The performance shift increases line pressure on the transmission and raises shift points and downshift points. The 01+ models just had the more aggressive shifting as their basic code in the PCM. Its kinda funny because they never removed the light from the DIC on the later models, so if you get a reprogrammed PCM you have to enable the Performance Shift for the different shift points and stuff to be enabled and if you hook it up the light comes on. I thought it was weird on my dads '02 that a Performance Shift light came on since the car didn't originally have it. Shawn Quote
Dannymik Posted November 28, 2004 Report Posted November 28, 2004 After reading that I can say that I have a plastic gas tank...sounds good to me since I live in an evil climate for rust! The 2001-2003 seem to be 100% identical. Quote
dbtk2 Posted November 28, 2004 Report Posted November 28, 2004 After reading that I can say that I have a plastic gas tank...sounds good to me since I live in an evil climate for rust! The 2001-2003 seem to be 100% identical. Yes, you definately have a plastic gas tank. The '03's are a lot different than the '01-02's. Don't remember all the changes, but there are a lot of them and I never could figure out why they would make that many changes the year before a model change. Shawn Quote
Dannymik Posted November 28, 2004 Report Posted November 28, 2004 After reading that I can say that I have a plastic gas tank...sounds good to me since I live in an evil climate for rust! The 2001-2003 seem to be 100% identical. Yes, you definately have a plastic gas tank. The '03's are a lot different than the '01-02's. Don't remember all the changes, but there are a lot of them and I never could figure out why they would make that many changes the year before a model change. Shawn I will have to do some searching for those changes. This makes me curious to find out if they tried to weed out any flaws that my '02 has. Do you know of any other links? Quote
dbtk2 Posted November 28, 2004 Report Posted November 28, 2004 I will have to do some searching for those changes. This makes me curious to find out if they tried to weed out any flaws that my '02 has. Do you know of any other links? I highly doubt they fixed any problems from ealier years. Most of the changes I remember are stupid shit like the pillars not being the same so the gauge-pods don't work on the '03's. The GTP badge is different. Also, I'm not sure, but I thought I remembered reading that the PCM had much more aggressive torque management programming and the shift points were lower, and the governor was lower, but I could be wrong. I'm pretty sure everything they changed just fucked the car up. I would never buy a '98 or '03. Shawn Quote
Dannymik Posted November 28, 2004 Report Posted November 28, 2004 thanks, that makes me feel good! 8) Quote
jjs316 Posted November 28, 2004 Author Report Posted November 28, 2004 I will have to do some searching for those changes. This makes me curious to find out if they tried to weed out any flaws that my '02 has. Do you know of any other links? I highly doubt they fixed any problems from ealier years. Most of the changes I remember are stupid shit like the pillars not being the same so the gauge-pods don't work on the '03's. The GTP badge is different. Also, I'm not sure, but I thought I remembered reading that the PCM had much more aggressive torque management programming and the shift points were lower, and the governor was lower, but I could be wrong. I'm pretty sure everything they changed just fucked the car up. I would never buy a '98 or '03. Shawn Why only a 98 or a 03? or do you mean 98-03? Quote
dbtk2 Posted November 28, 2004 Report Posted November 28, 2004 Why only a 98 or a 03? or do you mean 98-03? I mean 98 & 03, not 98-03. the '03's were an oddball year and they are just really weird, and the '98's had some Electrical changes that were only in that year (making them an oddball year as well), because in '99 GM changed the stuff back to how it was in '97. The only years I would get are '97, '99-02, and '04+, but due to PCM and intake changes I would try to stay away from '97's, but they really aren't that bad. Shawn Quote
Goph Posted November 28, 2004 Report Posted November 28, 2004 Fixed a problem with the wipers malfunctioning what was this problem because mine don't work right and i have a 2000 and that is under 99. Quote
