'96 Cutlass Headlight
Does anyone know if salvage yards regularly carry the miniquads for '96 coupes? I've called around but they're closed today (Sat. afternoon). The bulb is fine but a small crack has been letting water in for a while and the reflective coating has flaked off the actual housing. Figured I'd check before buying an entire unit for $25. Plus, no place I've called around here has them in stock--special order for some reason. If I can find a used housing I'm probably going to go the Silverstar route for all four. Also, if anyone on here has one lying around, I'm interested!:D RH high beam-H4352. Thanks.
