rhynda Posted November 26, 2004 Report Share Posted November 26, 2004 :?: Recall list for 1994 Cutlass Supreme SL Quote Link to comment Share on other sites More sharing options...
sl3196 Posted November 26, 2004 Report Share Posted November 26, 2004 http://www.nhtsa.dot.gov/ Edit because I'm bored: Make : OLDSMOBILE Model : CUTLASS Year : 1994 Manufacturer : GENERAL MOTORS CORP. NHTSA CAMPAIGN ID Number : 97V017000 Recall Date : FEB 04, 1997 Component: VISIBILITY:WINDSHIELD WIPER/WASHER:SWITCH/WIRING Potential Number Of Units Affected : 349331 Summary: SOME OF THESE VEHICLES HAVE A STRAINED OR SEPARATED WASHER/WIPER SWITCH POWER FEED WIRE. Consequence: THIS CAN CAUSE THE WINDSHIELD WASHER/WIPER TO WORK INTERMITTENTLY AND COULD ULTIMATELY RESULT IN INOPERATIVE WIPERS. IF THIS WERE TO OCCUR IN A SEVERE WEATHER SITUATION, DRIVER VISIBILITY COULD BE REDUCED, INCREASING THE RISK OF A VEHICLE CRASH. Remedy: DEALERS WILL INSPECT AND REPLACE THE OLD DESIGNED WASHER/WIPER SWITCHES WITH A NEWLY DESIGNED SWITCH. Notes: OWNER NOTIFICATION: OWNER NOTIFICATION IS EXPECTED TO BEGIN DURING MARCH 1997. NOTES: OWNERS WHO TAKE THEIR VEHICLES TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND DO NOT RECEIVE THE FREE REMEDY WITHIN A REASONABLE TIME SHOULD CONTACT CHEVROLET AT 1-800-222-1020, BUICK AT 1-800-521-7300, OLDSMOBILE AT 1-800-442-6537, OR PONTIAC AT 1-800-762-2737. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393. Make : OLDSMOBILE Model : CUTLASS Year : 1994 Manufacturer : GENERAL MOTORS CORP. NHTSA CAMPAIGN ID Number : 94V211000 Recall Date : OCT 19, 1994 Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:HOSES, LINES/PIPING, AND FITTINGS Potential Number Of Units Affected : 70676 Summary: THE BRAKE LINES CAN CONTACT THE TRANSMISSION MOUNTING BRACKET OF THE FRAME SIDE RAIL. THE LINES CAN WEAR THROUGH RESULTING IN LOSS OF BRAKE FLUID, AND EVENTUAL LOSS OF HALF THE VEHICLE BRAKING SYSTEM. Consequence: A LEAK IN THE HYDRAULIC BRAKE LINE WILL CAUSE A LOSS OF ONE HALF THE VEHICLE BRAKING SYSTEM AND EXTENDED BRAKING DISTANCES WHICH CAN RESULT IN AN ACCIDENT. Remedy: DEALERS WILL INSPECT FOR PROPER BRAKE LINE CLEARANCE AND REPOSITION THE BRAKE LINES. BRAKE LINES FOUND TO HAVE INDENTATIONS WILL BE REPLACED. Notes: SYSTEM: BRAKES; HYDRAULIC; LINES; NON-METALLIC. VEHICLE DESCRIPTION: PASSENGER VEHICLES. NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND THE REMEDY IS NOT PROVIDED FREE OF CHARGE WITHIN A REASONABLE TIME OR THE REMEDY DOES NOT CORRECT THE DEFECT, PLEASE CONTACT OLDSMOBILE AT 1-800-442-6537. ALSO, CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393. Make : OLDSMOBILE Model : CUTLASS Year : 1994 Manufacturer : GENERAL MOTORS CORP. NHTSA CAMPAIGN ID Number : 95V061000 Recall Date : MAR 17, 1995 Component: SERVICE BRAKES, HYDRAULIC:FOUNDATION COMPONENTS:HOSES, LINES/PIPING, AND FITTINGS Potential Number Of Units Affected : 199572 Summary: THE REAR WHEEL BRAKE HOSE(S) CAN CONTACT THE REAR SUSPENSION COMPONENTS CAUSING THE BRAKE HOSE(S) TO WEAR THROUGH. Consequence: THIS CONDITION CAN CAUSE LOSS OF BRAKE FLUID AND EVENTUAL LOSS OF THE VEHICLE BRAKING SYSTEM INCREASING THE POTENTIAL FOR A VEHICLE ACCIDENT. Remedy: DEALERS WILL INSPECT FOR PROPER BRAKE HOSE POSITION AND REPLACE THOSE HOSES IN AN INCORRECT POSITION WITH NEW HOSES AND CORRECTLY ROUTED. Notes: SYSTEM: BRAKES; HYDRAULIC; LINES; HOSE; NON-METALLIC. VEHICLE DESCRIPTION: PASSENGER VEHICLES. NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER ON AN AGREED UPON SERVICE DATE AND THE REMEDY IS NOT PROVIDED FREE OF CHARGE WITHIN A REASONABLE TIME, PLEASE CONTACT BUICK AT 1-800-521-7300 OR OLDSMOBILE AT 1-800-442-6537. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETY ADMINISTRATION'S AUTO SAFETY HOTLINE AT 1-800-424-9393. Make : OLDSMOBILE Model : CUTLASS Year : 1994 Manufacturer : GENERAL MOTORS CORP. NHTSA CAMPAIGN ID Number : 93V162000 Recall Date : SEP 20, 1993 Component: VEHICLE SPEED CONTROL Potential Number Of Units Affected : 579 Summary: THE CRUISE CONTROL CABLE MAY SEPARATE FROM THE CONDUIT END FITTING WHILE ENGAGED AND ACCELERATOR CONTROL COULD BE LOST. Consequence: LOSS OF ACCELERATOR CONTROL MAY NOT REDUCE ENGINE SPEEDTO A LEVEL ANTICIPATED BY THE DRIVER. ALTHOUGH THE VEHICLE CAN STILL BE STOPPEDWITH THE SERVICE BRAKE, LOSS OF ACCELERATOR CONTROL COULD RESULT IN A VEHICLECRASH WITHOUT PRIOR WARNING. Remedy: REPLACE THE CRUISE CONTROL CABLE. Notes: SYSTEM: EQUIPMENT; SPEED CONTROL.VEHICLE DESCRIPTION: PASSENGER CARS WITH 3.1L ENGINES AND CRUISE CONTROL.NOTE: IF YOUR VEHICLE IS PRESENTED TO AN AUTHORIZED DEALER ON AN AGREED UPONSERVICE DATE AND THE REMEDY IS NOT PROVIDED WITHIN A REASONABLE TIME AND FREEOF CHARGE OR THE REMEDY DOES NOT CORRECT THE DEFECT OR NONCOMPLIANCE, PLEASECONTACT BUICK SERVICE CENTER AT 1-800-521-7000 OR OLDSMOBILE SERVICE CENTERAT 1-800-442-6537. ALSO CONTACT THE NATIONAL HIGHWAY TRAFFIC SAFETYADMINISTRATION AUTO SAFETY HOTLINE AT 1-800-424-9393. Call the dealer with your vin and they will tell you which ones need done. Quote Link to comment Share on other sites More sharing options...
Kalgorn Posted November 26, 2004 Report Share Posted November 26, 2004 Does it matter what dealer you call and give your VIN to? I went to that page and checked out '92 Z34s. ake : CHEVROLET Model : LUMINA Year : 1992 Manufacturer : GENERAL MOTORS CORP. NHTSA CAMPAIGN ID Number : 92V161000 Recall Date : OCT 26, 1992 Component: FUEL SYSTEM, GASOLINE Potential Number Of Units Affected : 1058 Summary: THERE IS FUEL LEAKAGE AT THE FUEL TANK FILL AND/OR VENT PIPE EXTENSION SOLDER JOINTS. Consequence: FUEL LEAKS CAN LEAD TO A VEHICLE FIRE IF EXPOSED TO ASOURCE OF IGNITION. Remedy: REPLACE THE FUEL TANK. Notes: SYSTEM: FUEL SYSTEM.VEHICLE DESCRIPTION: PASSENGER CARS WITH METHANOL/ETHANOL FUEL SYSTEMS. I believe that I have that problem. If I get pretty low on gas, when I reach my destination and park the car I can hear a loud, constant beeping noise from the fill area. To stop it I either have to just wait or I can open the fill cap a bit and let the fumes out. Think this sounds like the recall? Quote Link to comment Share on other sites More sharing options...
HokemBokem Posted November 26, 2004 Report Share Posted November 26, 2004 If you take your car to the dealer becasue of one of these recalls will they fix it for free? Or will you have to pay for labor or something? Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted November 26, 2004 Report Share Posted November 26, 2004 If you take your car to the dealer becasue of one of these recalls will they fix it for free?? Well, they're supposed to, anyway... Quote Link to comment Share on other sites More sharing options...
