Guest TurboSedan Posted November 24, 2004 Report Posted November 24, 2004 today i found my Craftsman valve spring compressor and decided to try and R & R a valve in one of my TGP heads. after a few minutes i had the valve out and back in....much easier than i expected but how do i remove the old valve seal? just yank it out of there or? anything special i should know about when reinstalling the valve? am i supposed to use some kind of grease or something on the valve keepers when i put it back together? sorry if that's a stupid question but i'm totally new to this. oh and how should i go about cleaning the valves themselves before reassembly? thanks Quote
93CutlassSupreme Posted November 24, 2004 Report Posted November 24, 2004 i've just used mineral spirts on valves before i put them back in the head Quote
Guest TurboSedan Posted November 24, 2004 Report Posted November 24, 2004 yeah i was wanting to maybe use a SS wire brush wheel on my Dremel (or a bench wheel) and some Brakleen. i won't try that though unless i know for sure it won't hurt anything. Quote
Guest Anonymous Posted November 25, 2004 Report Posted November 25, 2004 Ever use a glass bead blasting machine? That will clean those valves up quick. Quote
Guest TurboSedan Posted November 25, 2004 Report Posted November 25, 2004 Ever use a glass bead blasting machine? That will clean those valves up quick. yeah i just haven't had access to one since high school shop class Quote
Brian P Posted November 25, 2004 Report Posted November 25, 2004 I can just assume the heads are off the block, lol. Just wipe them down good if they're not that bad. The keepers I used a magnetic wand to take them out and the reinstall I CAREFULLY put them back in. Those things can go flying, don't lose em! Quote
Guest Anonymous Posted November 25, 2004 Report Posted November 25, 2004 Ever use a glass bead blasting machine? That will clean those valves up quick. yeah i just haven't had access to one since high school shop class Send the valves to me. I can blast them at work. Or are you in a hurry? Quote
Guest TurboSedan Posted November 25, 2004 Report Posted November 25, 2004 I can just assume the heads are off the block, lol. Just wipe them down good if they're not that bad. The keepers I used a magnetic wand to take them out and the reinstall I CAREFULLY put them back in. Those things can go flying, don't lose em! ok i just got done pulling all of the valves out. i almost lost one of them damn keepers :shock: fwiw i now have all the valvetrain parts in thier own labeled ziplock bags if it even matters (1E, 1I, 2E, 2I, 3E etc etc). i was starting to think #5 intake valve was bent because the fucker wouldn't come out but i sprayed some WD-40 into the intake port and it finally slid right out (lots of rust in there). other than that everything seems fine besides lots of carbon crud. right now the VIN 'T' engine is in the garage on the engine stand stripped down to the shortblock and cleaned...waiting for me to put it all back together. my head gaskets, head bolts, valve seals etc haven't gotten here yet. this 'T' engine is getting the heads from my TGP engine (and all other turbo parts). the 'V' engine is on another engine stand tucked back in the corner of the garage. Quote
Guest TurboSedan Posted November 25, 2004 Report Posted November 25, 2004 Send the valves to me. I can blast them at work. Or are you in a hurry? i might, just want to avoid the shipping if i can lol. i'm hoping to have the heads cleaned and back together with new seals next week sometime. hopefully i'll have the heads and lower intake back on then too. still not sure if i should try checking the heads for flatness myself with a straight edge & feeler gauges or just have a shop do it :?: i want to avoid resurfacing if possible. Quote
sl3196 Posted November 25, 2004 Report Posted November 25, 2004 Josh just sneak into the highschool and use their machine. Who knows maybe if you ask the shop teacher he may let you do it. Quote
Guest TurboSedan Posted November 25, 2004 Report Posted November 25, 2004 Josh just sneak into the highschool and use their machine. Who knows maybe if you ask the shop teacher he may let you do it. damn that's a good idea (the high school auto shop is literally across the street from my apartment lol). my brother is a junior in high school and he's in auto shop IIRC....i'll ask him tonight. Quote
