Will the rims from a 1997 thru 2003 GTP fit on a 1994 GTP. I seem to be getting real good HONEST answer at this forum so I figured I would ask here. I have decided to not go back to the OTHER forums I was apart of ever again and continue to be a member of this forum..
Bullet 8)
Guest TurboSedan
i've heard spacers are a bad idea. something about having to use longer wheel studs and being unsafe because the studs can shear off or something?
i wish i could put some '97+ GP swept crosslace wheels on my car, but i don't think i'll chance it.
Why spacers? And where do I get them?
They won't clear the front calipers. I think you'd need 13mm (1/2") spacers. You can get the best price on Ebay. For a spacer that big, you would definitely need longer lugs.
My aftermarket wheels also wouldn't clear the calipers since they're concave. I used 5mm spacers and shaved the front caliper bracket. No problems at all with my small 5mm spacers.
