honda_bot Posted November 23, 2004 Report Posted November 23, 2004 Bad gas>old injectors :dammit: My engine almost dies when I step on the gas, but after almost an eternity(really about .5 sec.), it accelerates. I got about 95K and never used fuel inj. cleaner But, I hear that the injectors can be cleaned instead of replaced. they are all still good, about 12ohms on each. Thanks for the help! Quote
terryk2003 Posted November 23, 2004 Report Posted November 23, 2004 get some BLASTER brand fuel injector cleaner and dump it into the gas tank with a full tank of gas...thats ONE way to do it @ least... Quote
95 3-4 Posted November 23, 2004 Report Posted November 23, 2004 I think Napa can do it, and other "real" autoparts stores too, some stock cleaned injectors and just take your old ones and give you the rebuilt's for about half the price of a new injector Quote
93CutlassSupreme Posted November 23, 2004 Report Posted November 23, 2004 Bad gas>old injectors :dammit: My engine almost dies when I step on the gas, but after almost an eternity(really about .5 sec.), it accelerates. I got about 95K and never used fuel inj. cleaner But, I hear that the injectors can be cleaned instead of replaced. they are all still good, about 12ohms on each. Thanks for the help! think it's injectors? my car has done the same thing as long as i've had it. i just got used to it because i couldn't figure out what it was Quote
Guest TurboSedan Posted November 23, 2004 Report Posted November 23, 2004 while we're on the subject does anyone know of a place (online maybe?) that i could send my TGP injectors to be cleaned and sent back to me? i've heard of other people doing that....i wonder how much it costs? Quote
kcac Posted November 23, 2004 Report Posted November 23, 2004 http://www.lindertech.com/reconinj.htm http://www.asashop.org/autoinc/june98/techtotech.htm http://www.asashop.org/autoinc/sept98/techtotech.htm Quote
Stealth Posted November 23, 2004 Report Posted November 23, 2004 my car does it to but my injectors where purged at a garage Quote
phantomshado Posted November 23, 2004 Report Posted November 23, 2004 my old cutlass did it too, I don't think its the injectors, in fact I always felt that after dumping in a can of injector cleaner it, it actually ran a little rougher. Its more than likely the fuel pump, or fuel filter. Have you changed the plugs in awhile? Also, I have seen alternators running out the door make some odd idle issues like bogging from a dead stop... Quote
Jcrow Posted November 23, 2004 Report Posted November 23, 2004 I cleaned my injectors in an ultra sonic cleaner in a caustic solution of sodium hydroxide and hot water. I cycled them on and off during the cleaning. It did fix one that leaked, and the water was black when I was done. I then pulsed fuel injector cleaner through them, and measured how much came out in a graduated cylinder. When they all looked good I put them in the car. After all this I get a bog when I accelerate from a stop! I didn't use new intake gaskets. Maybe I have a vacuum leak? Quote
Guest TurboSedan Posted November 26, 2004 Report Posted November 26, 2004 http://www.lindertech.com/reconinj.htmhttp://www.asashop.org/autoinc/june98/techtotech.htm http://www.asashop.org/autoinc/sept98/techtotech.htm thanks for the links, great info Quote
