maybe2fast Posted November 22, 2004 Report Share Posted November 22, 2004 with the Gen 1 3800 the injectors are kinda wimpy. If I were to upgrade to a larger injector (higher psi). It won't give hp will it? Is there an advantage to doing this? thanks fellaz Quote Link to comment Share on other sites More sharing options...
phantomshado Posted November 22, 2004 Report Share Posted November 22, 2004 you'll only be able to spray more fuel, which won't happen unless you change your computer, toss on a super/turbocharger, or trick your map to think its at wot all the time, but then you'll want to up your fuel pump. If you aren't going to alter the breathing of the car I doubt changing the injectors to anything larger would really help anything. You'd end up running rich all the time, and that will kill an o2 sensor faster than normal, and you'll get shit for gas economy. I wouldn't bother. Quote Link to comment Share on other sites More sharing options...
