asonofabeachnj Posted November 22, 2004 Report Posted November 22, 2004 Does anyone know if there is a belt made or if a belt from another vehicle wouldwork on the 3100 v6 if i remove my ac compressor. mine is shot and figured id just eliminate it all together. Quote
Robby1870 Posted November 23, 2004 Report Posted November 23, 2004 Im with the idea of just replacing the compressor, but I know 3.1Ls were available in 88 with no A/C. But if you cut out the A/C you'll need an idler there. Plus, I dont know if a 3.1L belt would work on a 3100. So, after all that rambling, just replace the compressor Quote
EurosportZ34 Posted November 23, 2004 Report Posted November 23, 2004 replace the compressor...it will save you alot of hassle Quote
Dannymik Posted November 24, 2004 Report Posted November 24, 2004 you can get one at the j/y for around $60 and up...or go to a u-pull it for much cheaper. I drove with a stuck clutch in my a/c compressor for a long time. Quote
93CutlassSupreme Posted November 24, 2004 Report Posted November 24, 2004 or, you could just leave it. i developed a massive freon leak mid summer, and since i refuse to spend any more on my ride, i just left it. Quote
z34_nut Posted November 24, 2004 Report Posted November 24, 2004 theres no clutch on our AC compressors. they ar V5 type compressors. variable displacement. it is always turning and always on. the only thing that changes is a vacuum oriented valve that tells the compresser to change its displacment to move R-12. apperently i heard that R-134a conversions are easy for w-bodies. that is if the compressor works and the h-block is working correctly. other then that, all you need to do it add a new accumulator and adaptors. Quote
Whiskey River Posted November 24, 2004 Report Posted November 24, 2004 theres no clutch on our AC compressors. they ar V5 type compressors. variable displacement. it is always turning and always on. the only thing that changes is a vacuum oriented valve that tells the compresser to change its displacment to move R-12. apperently i heard that R-134a conversions are easy for w-bodies. that is if the compressor works and the h-block is working correctly. other then that, all you need to do it add a new accumulator and adaptors. The V5 compressor does have a clutch. When the clutch is engaged the compressor attempts to maintain a low side pressure of 28-35 psi by adjusting the stroke of the swash plate inside. The low side pressure is good for R-12 as this means you will have a core temp of 30-35 degrees not so good for R-134 as your core temps will generally be 33-45 degrees. Quote
