pitzel Posted November 20, 2004 Report Share Posted November 20, 2004 Ok, so I go to reinstall my alternator today, and there is a rear mounting bracket that seems to have worked its way lose and is no longer attached anywhere but my alternator: Where does that support/attachment brace, on a 1992 3.1L V6 engine, on the right-hand (facing the engine/alternator) side of the rear part of the alternator connect to? I am obviously missing a bolt on the other end, so it must connect somewhere. Quote Link to comment Share on other sites More sharing options...
GPXSS Posted November 20, 2004 Report Share Posted November 20, 2004 it bolts to the rear head, the hole over the middle exhaust port. Ignore the stud I used, you will just use a bolt with a 13mm head. Quote Link to comment Share on other sites More sharing options...
kcac Posted November 20, 2004 Report Share Posted November 20, 2004 Here's another view. This is from a 1990 Factory Service Manual. Looks to be the same. Quote Link to comment Share on other sites More sharing options...
pitzel Posted November 20, 2004 Author Report Share Posted November 20, 2004 Weird, cuz mine totally wasn't hooked to anything. Would this have a significant effect on the overall alternator grounding? Quote Link to comment Share on other sites More sharing options...
Guest TurboSedan Posted November 20, 2004 Report Share Posted November 20, 2004 no. i don't even use that brace on mine because i lost the bolt as well. mine hasn't had a brace for a LONG time :oops: Quote Link to comment Share on other sites More sharing options...
pitzel Posted November 21, 2004 Author Report Share Posted November 21, 2004 Ok, so the dealer was nice enough to give me the required bolt. Hopefully my electrical problems are solved as of tomorrow; I already had to dissassemble my *brand new* alternator tonight because of crappy assembly of the voltage output terminal assembly. Thanks everyone. Beers all 'round Quote Link to comment Share on other sites More sharing options...
