dohc v6 Posted November 19, 2004 Report Share Posted November 19, 2004 i need the torque settings for the a/c bracket bolts to block and the alternator bracket to block bolts. all for a 3.4 Quote Link to comment Share on other sites More sharing options...
Aaron Posted November 19, 2004 Report Share Posted November 19, 2004 As far as torque specs, you won't ever get a torque wrench in there They should go pretty tight given it si a cast iron block. You shouldn't have any issues stripping them. Just go with what feels right, but do go kinda tight on them. I usually use a 3/8" drive ratchet, and go from there. Don't use a 1/2" drive though, that much tq is not neccesary. Quote Link to comment Share on other sites More sharing options...
GPXSS Posted November 20, 2004 Report Share Posted November 20, 2004 45-60ft/lbs should do it. 60ft/lbs is around kungfugrip tight using a standard 3/8" ratchet, as much as you can go. More than that and you need a breaker bar or a pipe. Quote Link to comment Share on other sites More sharing options...
z34_nut Posted November 20, 2004 Report Share Posted November 20, 2004 As far as torque specs, you won't ever get a torque wrench in there They should go pretty tight given it si a cast iron block. You shouldn't have any issues stripping them. Just go with what feels right, but do go kinda tight on them. I usually use a 3/8" drive ratchet, and go from there. Don't use a 1/2" drive though, that much tq is not neccesary. um, theres a thing called a torque ratchet, works just like your standard ratchet. have fun. Quote Link to comment Share on other sites More sharing options...
Brian P Posted November 21, 2004 Report Share Posted November 21, 2004 As far as torque specs, you won't ever get a torque wrench in there They should go pretty tight given it si a cast iron block. You shouldn't have any issues stripping them. Just go with what feels right, but do go kinda tight on them. I usually use a 3/8" drive ratchet, and go from there. Don't use a 1/2" drive though, that much tq is not neccesary. um, theres a thing called a torque ratchet, works just like your standard ratchet. have fun. yup, some people know.... Quote Link to comment Share on other sites More sharing options...
