Stealth Posted November 18, 2004 Report Posted November 18, 2004 ok I kinda need help fast, because the cars undriveable, I cant figure this out, heres the rear end all 8 bulbs work reverse lights all work when 4 ways on only farthest right 1 blub lights when brakes on 3rd brake light and farthest right 1 bulb light right turn signal doesnt work the light comes stays solid then goes off left turn signal works but slow and seems weak all bulbs on left light I checked the fuses in the glove box there all fine, if its the flasher why dont the brake lights work? btw how and where is the flasher?? Quote
DiscoStudd Posted November 19, 2004 Report Posted November 19, 2004 The flasher is underneath the dash near where the steering column passes through the firewall. If the brake lights are screwed, and you're sure the bulbs are all good, then your signal switch is shot. What year is your Cutty? If it's a 94-97 CLICK HERE for the answer to your prayers... Quote
Stealth Posted November 19, 2004 Author Report Posted November 19, 2004 ok I fixed it, one of thr high beams was burnt, kinda pathetic really, anyways I still think the flashers shot its taking like 4-5 seconds before it starts to blink and ots goign really slow Quote
supreme_style21 Posted November 19, 2004 Report Posted November 19, 2004 All that because of a burnt out headlight bulb? I dunno man.. Quote
Brian P Posted November 19, 2004 Report Posted November 19, 2004 SIGNAL SWITCH TIME!113we3rrffggghsthdfnmghnmtyujekjrtuklyuik Quote
Stealth Posted November 19, 2004 Author Report Posted November 19, 2004 whilr the turn signal switch is worn out I replaced the flasher and its blinking normaly now, I got an electronic one Quote
CuttySup Posted November 20, 2004 Report Posted November 20, 2004 whilr the turn signal switch is worn out I replaced the flasher and its blinking normaly now, I got an electronic oneDoes the new flasher make your turn signals flash any faster? Quote
Stealth Posted November 21, 2004 Author Report Posted November 21, 2004 umm It wasnt blinkign normaly, it was taking like 5 seconds before it started blinking then it was slow, It was a mechanical one, I bought an electronic one maybe thats why Quote
