Just as the title says, have you done it?
If so please throw me a bone, details. Mainly parts used.
I looked on the main w-body page for the info and it is confusing. I am not sure if you do need the hibs from the newer car..... So I figured I would try and hit up someone who has done it or had hard core knowledge of it.....
Thanks
D
P.S. Front went with out a hitch....!!! Hubs transfer then your done...
new/used larger caliper
new/used pads
new/used rotors
bolts to hold the calipers(these bolts changed in length)
think that should do it. you need to remove the dust sheilds to install the larger setup.
Guys, help me out if i left some important information out...
he about hit the nail on the head.
you need everything here x2 (in other words, both rear calipers)
http://www.w-body.com/images/new_caliper_diagram.gif
then new pads/rotors. Also be aware that the parking brake system from the newer cars will not bolt right up, and you'll have to play with it a little bit.
http://home.comcast.net/~aldridgec/TGP/brakes/rear_brake_upgrade.htm
bottom of that page is the best (only really) solution I've seen.
Also be aware that I think your current spare tire won't fit over the new calipers (I THINK...)
simple.
Basically it's just....
remove tire
remove caliper
remove rotor
remove dust shield
remove old pads from new caliper
install new rotor
install new caliper with proper bolts and new pads
bleed brakes
hook up e brake if desired.
put back on tire
that's a quick step thru of it. It's not really that hard, just take your time, and you'll get it done
Guest TurboSedan
you're right, it won't fit. you'll need a '94+ spare tire, the '88-'93 spare is smaller and it will rub the newer caliper (been there done that :bash: )
That's what I was hoping. Thanks guys/gals(if there was any).
And yes I know I need two of everything.....
So really what does this convert do other than ditch those crappy seazing calipers? Are they of diff size?
THanks again guys....
D
Awesome. I'm off to find me... some money. :x
But after that, im going to the yard.
