Guest Gp crazy Posted November 13, 2004 Report Posted November 13, 2004 1990 GP Ste Hit a bumb then the headlights went out low beam not working but high were working? I have no idea where search for this stuff in the headlight system. relay, fusible link, bad wire, diode or switch both bulb's can't be bad can they? Well I bought new one's anyways 9006 low beams right? $ 17.63 sylvanaia Xtra Vision at wal-mart. it figures if you replace one you should replace both 8) Quote
EurosportZ34 Posted November 13, 2004 Report Posted November 13, 2004 for some reason i don't think the problems with the lights themselves. my Escort had problems with the headlights turning on and it was in the wiring with the switch so i'd check your wiring. out maybe every time you run over a bump it pops the wires outta place Quote
digitaloutsider Posted November 13, 2004 Report Posted November 13, 2004 And this post will be magically whisked away to the General section. Quote
EurosportZ34 Posted November 13, 2004 Report Posted November 13, 2004 And this post will be magically whisked away to the General section. yeah for sure, i didn't even see that when i posted in the words of turby "consider this your warning" hehehe... Quote
Guest Gp crazy Posted November 14, 2004 Report Posted November 14, 2004 OK so I will look in to the wiring first then go from there thanks again sorry for posting this in the wrong place? Quote
White93z34 Posted November 14, 2004 Report Posted November 14, 2004 check wiring, as well as the AUX terminal near the battery. Quote
