pitzel Posted November 13, 2004 Report Share Posted November 13, 2004 Ok, so when I wired my 2.1W Cutlass Supreme DIS into my 1992, the fuel level sensor is reading '99%' when I do the DEST, RESET, 8192 thing. I have roughly 3/4 of a tank of fuel, and I am pretty sure I tapped the right wire. Anyone else have this problem? With the fuel level showing 99% even though the tank isn't full? Quote Link to comment Share on other sites More sharing options...
jeremy Posted November 13, 2004 Report Share Posted November 13, 2004 the low fuel level on my DIC doesn't work but that is because my car is OBDII Quote Link to comment Share on other sites More sharing options...
TeeJay3800 Posted November 13, 2004 Report Share Posted November 13, 2004 I have version 2.1W as well, but my DIS gives the fuel readout as "gallons used". There is no percentage readout for fuel remaining that I have ever heard of. Unless that is something the diagnostic mode tells you..... Quote Link to comment Share on other sites More sharing options...
pitzel Posted November 13, 2004 Author Report Share Posted November 13, 2004 I have version 2.1W as well, but my DIS gives the fuel readout as "gallons used". There is no percentage readout for fuel remaining that I have ever heard of. Unless that is something the diagnostic mode tells you..... Hit DEST, then hit RESET, then type 8192, and you will get a display showing some numbers. The 2nd group of numbers, right before the character 'L', should be the fuel quantity remaining expressed as a percentage. Quote Link to comment Share on other sites More sharing options...
TeeJay3800 Posted November 13, 2004 Report Share Posted November 13, 2004 I know how to get into DIAG mode, how do you think I knew my version? I never did bother to figure out what the string of numbers means so that's interesting. What do the other two numbers mean? Quote Link to comment Share on other sites More sharing options...
pitzel Posted November 13, 2004 Author Report Share Posted November 13, 2004 One is dimmer intensity, and the other is fuel tank %'age. I rechecked my wiring, and it all checks out okay. So I am thinking it might be a grounding issue on the harness that carries the VSS/ALDL/Fuel Tank/GND lines. Where do you guys usually end up grounding these lines and is the ground 100% necessary on that particular harness? I am thinking that my DIS might be having trouble reading the fuel tank sender properly because of the effectiveness of the grounding. Quote Link to comment Share on other sites More sharing options...
