dohc v6 Posted November 11, 2004 Report Share Posted November 11, 2004 ok i want to know if this is a good plan 1 i am going to drain all fluids except oil and remove battery 2 take off plenum and brake master cyclinder 3 take off spark plug wires becuause they are every where and take out radiator. 4. remove all hoses and wire connection 5. lift car on jack stands 6. take off front grill so doesnt get scratch 7. disconnect exhuast and take axels out 8 drain oil and remove hood. 9. put engine lift in place and start pulling it out and have a helper watch to make sure it is going ok. 10 put in trailer on 2 pieces of wood and bring home and put on engine stand questions - are there only 2 bolts for the mastercyclinder what are all the hoses and wire connections can i take the engine out with the car jaked up can i take the axels out with out removing the strut assembles will the downpipe come out just disconnecting it from the engine and the rest of the pipe or will it get cought am i missing anything Quote Link to comment Share on other sites More sharing options...
Brian P Posted November 11, 2004 Report Share Posted November 11, 2004 questions - are there only 2 bolts for the mastercyclinder what are all the hoses and wire connections can i take the engine out with the car jaked up can i take the axels out with out removing the strut assembles will the downpipe come out just disconnecting it from the engine and the rest of the pipe or will it get cought Just off the top of my head: you're taking the engine and trans out at the same time? A DOHC? If you're wanting to get the engine on a stand, you gotta separate the engine and tranny. Quote Link to comment Share on other sites More sharing options...
Intimidatorz34 Posted November 11, 2004 Report Share Posted November 11, 2004 ok i want to know if this is a good plan 1 i am going to drain all fluids except oil and remove battery 2 take off plenum and brake master cyclinder 3 take off spark plug wires becuause they are every where and take out radiator. 4. remove all hoses and wire connection 5. lift car on jack stands 6. take off front grill so doesnt get scratch 7. disconnect exhuast and take axels out 8 drain oil and remove hood. 9. put engine lift in place and start pulling it out and have a helper watch to make sure it is going ok. 10 put in trailer on 2 pieces of wood and bring home and put on engine stand questions - are there only 2 bolts for the mastercyclinder what are all the hoses and wire connections can i take the engine out with the car jaked up can i take the axels out with out removing the strut assembles will the downpipe come out just disconnecting it from the engine and the rest of the pipe or will it get cought am i missing anything Remove the two downpipe bolts from just downstream of the 02 sensor, be sure to disconnect o2 sensor wires. Other wires to remove off the top of my head: starter, tranny, steering, alternator. Be sure to unbolt the ps pump and ps lines from the front of the engine as well as the a/c. ( I removed the a/c and drained it into the air/ground , just stay away from it in a well ventilated area if you drain it). You can remove it with it on jackstands, assuming the lift you have can go high enough. Once the tranny and engine are out, lower them onto an old tire, unbolt the tranny( you will have to remove the starter and crank the engine to remove the 3 torque convertor bolts.) Then you can bring the engine home. Quote Link to comment Share on other sites More sharing options...
White93z34 Posted November 12, 2004 Report Share Posted November 12, 2004 it helps to have old tires to set the engine on when you load it on the trailer or truck, then use tow straps to hold it down Quote Link to comment Share on other sites More sharing options...
Carotop Posted November 12, 2004 Report Share Posted November 12, 2004 Whats a good list of things to keep when getting a "new" engine and taking out the old one? Quote Link to comment Share on other sites More sharing options...
White93z34 Posted November 12, 2004 Report Share Posted November 12, 2004 Whats a good list of things to keep when getting a "new" engine and taking out the old one? if you are just replaceing an engine for an engine of same year make model , blah blah blah, definately keep the: alternator, ac compressor, spark plugs, wires, sensors, plenum, pulleys, prety much anything that MAY be of value. Quote Link to comment Share on other sites More sharing options...
93CutlassSupreme Posted November 12, 2004 Report Share Posted November 12, 2004 Whats a good list of things to keep when getting a "new" engine and taking out the old one? if you are just replaceing an engine for an engine of same year make model , blah blah blah, definately keep the: alternator, ac compressor, spark plugs, wires, sensors, plenum, pulleys, prety much anything that MAY be of value. could of just said all the accessories Quote Link to comment Share on other sites More sharing options...
White93z34 Posted November 12, 2004 Report Share Posted November 12, 2004 Whats a good list of things to keep when getting a "new" engine and taking out the old one? if you are just replaceing an engine for an engine of same year make model , blah blah blah, definately keep the: alternator, ac compressor, spark plugs, wires, sensors, plenum, pulleys, prety much anything that MAY be of value. could of just said all the accessories i sure could have Quote Link to comment Share on other sites More sharing options...
dohc v6 Posted November 12, 2004 Author Report Share Posted November 12, 2004 so do i just have to disconnect the exhaust or do i have to take it out. Quote Link to comment Share on other sites More sharing options...
Intimidatorz34 Posted November 12, 2004 Report Share Posted November 12, 2004 so do i just have to disconnect the exhaust or do i have to take it out. Just unbolt the two downpipe bolts Quote Link to comment Share on other sites More sharing options...
dohc v6 Posted November 13, 2004 Author Report Share Posted November 13, 2004 ok so i was told by my dad to take just the engine out. now i can see 5 of the bolts but the 6 one i can see . these are the bolts that attach the tranny to the engine. how exactly does this 5 bolt come out Quote Link to comment Share on other sites More sharing options...
Intimidatorz34 Posted November 13, 2004 Report Share Posted November 13, 2004 I imagine you are talking about the 6th bolt that is attached from the opposite side of bellhousing. You probably need a big extension and access it from the passenger fenderwell. You also have 3 torque convertor bolts, and I believe there are 4 bolts that hold the tranny to a bracket mounted on the engine block on the passenger side. Quote Link to comment Share on other sites More sharing options...
