PCV on 2.8L
I can't quite figure out, from the Haynes manual, where the PCV is located on my '89 Regal 2.8L. Can any of y'all help me out here?
you might need to rotate your engine forwards (your Haynes will explain it) to access your PCV valve. it shouldn't be too hard to miss on the back of your engine.
  • 2 weeks later...
I had the same problem trying to find the damn thing too. Finally i found it on the rear valve cover. YOu shouldnt need to tilt the motor to get at it just remove the Sensor i believe its the MAF sensor and stick your hand down there. I think im the only one that can change his back 3 plugs with out tilting the motor ive done 3 or 4 other guys cars for them too without tilting the motor.
When I was 16 and knew zilch about these engines being able to tilt, I did the back 3 plugs and managed to break the map sensor vacuum line right where it "intersects" with another vac line. Bad events happened after that
I just no my these cars so well that i can change the back plugs with my eyes closed and using a swivil of the rachet.
