GutlessSupreme Posted November 2, 2004 Report Share Posted November 2, 2004 Alright. CS died on me Saturday. I was just cruisin along and I noticed the voltage dropping.. fuck. car died, I figured it was the alt. Thing just wouldn't charge. I finally got a chance to swap the alt. from the TGP aaaand... FUCK! It STILL won't CHARGE!!!! It starts, holds around 14.4 volts for 7 seconds or so, then just starts dropping off... what the hell could be wrong? Quote Link to comment Share on other sites More sharing options...
Kalgorn Posted November 2, 2004 Report Share Posted November 2, 2004 Battery? Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted November 2, 2004 Author Report Share Posted November 2, 2004 replaced in february. but if I get a chance i'm going to try swapping those two. I have so much work to do though.. :? Quote Link to comment Share on other sites More sharing options...
biff85ta Posted November 2, 2004 Report Share Posted November 2, 2004 Loose connection somewhere. Quote Link to comment Share on other sites More sharing options...
WhiteOut Posted November 2, 2004 Report Share Posted November 2, 2004 Loose connection somewhere. Check the auxillary positive terminal on the drivers side fender. Quote Link to comment Share on other sites More sharing options...
1990lumina Posted November 2, 2004 Report Share Posted November 2, 2004 Possibily a short in the system also somewhere? Quote Link to comment Share on other sites More sharing options...
93CutlassSupreme Posted November 2, 2004 Report Share Posted November 2, 2004 was it a cheap battery? my $30 Wal-Mart battery lasted about a year. try a good known battery from another car Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted November 3, 2004 Author Report Share Posted November 3, 2004 just swapped batterys... STILL NOTHING!!! what do I check on the aux postive post? just if the nut is tight? Quote Link to comment Share on other sites More sharing options...
HokemBokem Posted November 3, 2004 Report Share Posted November 3, 2004 just swapped batterys... STILL NOTHING!!! what do I check on the aux postive post? just if the nut is tight? Thats how I check it. Quote Link to comment Share on other sites More sharing options...
CodeRedZ24 Posted November 3, 2004 Report Share Posted November 3, 2004 if u tried alt batt and connections then has to be a short in the wiring Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted November 3, 2004 Author Report Share Posted November 3, 2004 the aux. terminal's fine... I don't even know where the fuck to begin looking for shorts better get the TGP on the road soon... Quote Link to comment Share on other sites More sharing options...
w-bodys_are_the_best Posted November 3, 2004 Report Share Posted November 3, 2004 hey what motor do you have, i have the 3100, and i was in a hurry putting it in and wasn't watching carefully, and one thing to check which i didn't is i accidently pinched the wire underneath the alternator, and it wouldn't charge either i finally figured that out, it's hard to see, and the wire was all melted and i had to re-wire it, so check for that, cause thats how i fuctup it's easy to do if u were in a hurry when u put it in Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted November 3, 2004 Author Report Share Posted November 3, 2004 It might be that, but it's not like the syptoms have changed from before I swapped the alt. or battery.. still same problem Quote Link to comment Share on other sites More sharing options...
HokemBokem Posted November 3, 2004 Report Share Posted November 3, 2004 the aux. terminal's fine... I don't even know where the fuck to begin looking for shorts better get the TGP on the road soon... Whats wrong with the TGP? Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted November 3, 2004 Author Report Share Posted November 3, 2004 need to replace steering column, fix ebrake, fix brake light switch, replace a bunch of bulbs, figure out it's random no-crank problem, fix the front bumper so it isn't rubbing the pass. tire when I turn, swap on good tires, get registered, inspected, insured... yea. Quote Link to comment Share on other sites More sharing options...
HokemBokem Posted November 3, 2004 Report Share Posted November 3, 2004 need to replace steering column, fix ebrake, fix brake light switch, replace a bunch of bulbs, figure out it's random no-crank problem, fix the front bumper so it isn't rubbing the pass. tire when I turn, swap on good tires, get registered, inspected, insured... yea. Well at least you will have some work to do Do you have any pics or anything? Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted November 3, 2004 Author Report Share Posted November 3, 2004 not yet, friend still has my camera... Quote Link to comment Share on other sites More sharing options...
HokemBokem Posted November 3, 2004 Report Share Posted November 3, 2004 When you get some send me a few. When do you think you will be done with those repairs? Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted November 4, 2004 Author Report Share Posted November 4, 2004 the two INJ (or ING? I forget) fuses on the pass. side fuse box were blown. all fixed. Quote Link to comment Share on other sites More sharing options...
rudefyet Posted November 4, 2004 Report Share Posted November 4, 2004 mess around with any fuses lately? Quote Link to comment Share on other sites More sharing options...
GPdriver1986 Posted November 4, 2004 Report Share Posted November 4, 2004 For some reason my volt gauge was showing a line below 13 and the car came with a new battery and alternator last year. Also my car starts up fine, is there anything i should be worried about? SORRY ABOUT THE HIJACK! Quote Link to comment Share on other sites More sharing options...
GutlessSupreme Posted November 4, 2004 Author Report Share Posted November 4, 2004 mess around with any fuses lately? no :? Quote Link to comment Share on other sites More sharing options...
rudefyet Posted November 4, 2004 Report Share Posted November 4, 2004 well check you ignition fuses to be safe Quote Link to comment Share on other sites More sharing options...
rudefyet Posted November 4, 2004 Report Share Posted November 4, 2004 wow i'm slow tonight Quote Link to comment Share on other sites More sharing options...
