perfecseal Posted November 2, 2004 Report Posted November 2, 2004 I have been haveing problomes with my regal so i took it to the shop and put it on the computer and it told me that the tps was bad .... I went to the parts store and got a new one Installed it and restarted the cars comp... Drove around fer about an hour and still have the same problome ...... Took it back to the shop back on the computer and got the same thing..... Eny thoughts I have fallowed the wires back to the firewall and they seem good so what now buy anuther TPS.....????? Quote
GP1138 Posted November 2, 2004 Report Posted November 2, 2004 I have been haveing problomes with my regal so i took it to the shop and put it on the computer and it told me that the tps was bad .... I went to the parts store and got a new one Installed it and restarted the cars comp... Drove around fer about an hour and still have the same problome ...... Took it back to the shop back on the computer and got the same thing..... Eny thoughts I have fallowed the wires back to the firewall and they seem good so what now buy anuther TPS.....????? What kind of problems is your Regal having? Describe the symptoms and anything else you've done. Also, what engine do you have? Quote
gpse_97 Posted November 2, 2004 Report Posted November 2, 2004 I have been haveing problomes with my regal so i took it to the shop and put it on the computer and it told me that the tps was bad .... I went to the parts store and got a new one Installed it and restarted the cars comp... Drove around fer about an hour and still have the same problome ...... Took it back to the shop back on the computer and got the same thing..... Eny thoughts I have fallowed the wires back to the firewall and they seem good so what now buy anuther TPS.....????? what is wrong with the TPS and what is the car doin? I had a problem with high idle and my TPS was causing it, all I did was close the idle adjuster screw a bit on my 3.4 DOHC and it fixed everything. What motor you got? 3800 series 1? Im sure you can drop the idle a bit by looking for the adjuster screw near the TB Quote
Slade901 Posted November 2, 2004 Report Posted November 2, 2004 What kind of problem you car is having in the first place? You may have to clear the error code first before running a computer scan again. Removing the battery cables for 15 minutes might clean the previous error code and have them test your computer (ECM) for any error codes again. Quote
Guest TurboSedan Posted November 2, 2004 Report Posted November 2, 2004 Im sure you can drop the idle a bit by looking for the adjuster screw near the TB i don't think so. idle RPM is a function of the IAC. the only way to change it would be to edit the 'chip'. you may want to remove the IAC pintle and clean it though. also, the TPS wires do not go to the firewall...they lead back to the underhood ECM near the fender. but yes get the wiring checked out....and please give us more info like what engine do you have? Quote
perfecseal Posted November 2, 2004 Author Report Posted November 2, 2004 sorry bout that its a 3.8 .. I removed the battery for 30 mins after installing the tps and the symotomes are..... 1 hard to start at times must hold gas to the floor ... witch of corse puts it into flood mode... when it dose start fine witch is half the time it will run for about a half and hour or so at idle then spit and sputter dieing all together ..after it dies it will not start back up agian for about 12 hours ....the car was given to me because of this problome .... Ohh it shows code 21 and 22 when hookded up.. Quote
gpse_97 Posted November 3, 2004 Report Posted November 3, 2004 Im sure you can drop the idle a bit by looking for the adjuster screw near the TB i don't think so. idle RPM is a function of the IAC. the only way to change it would be to edit the 'chip'. you may want to remove the IAC pintle and clean it though. also, the TPS wires do not go to the firewall...they lead back to the underhood ECM near the fender. but yes get the wiring checked out....and please give us more info like what engine do you have? Idle can be droped using the idle adjustment screw, if turned to high it'll cause a High idle (i had that issue), however you can't make big adjustments and the ECM does control most of the idle you are correct. Quote
Lee Posted November 4, 2004 Report Posted November 4, 2004 Would a crankshaft sensor that is going bad cause this? Mine (the first time) died and wouldn't start till cold. Then it ran five minutes perfectly and died again. Quote
