93CutlassSupreme Posted October 30, 2004 Report Posted October 30, 2004 sometimes my driver's door window won't power up. i can press the up button a million times and it won't budge. then, 2 minutes later, it will go up fine. would this be the switch? this is the only window that is fucked up Quote
midnight rider Posted October 31, 2004 Report Posted October 31, 2004 It sounds like the inside of your window switch is coroded. Take your switch out, take it apart and clean all the contacts with wd 40 and clean the conector before you put it all back together. Quote
EurosportZ34 Posted November 2, 2004 Report Posted November 2, 2004 hrmmm....seems like i just posted on this like last week Quote
Brian P Posted November 2, 2004 Report Posted November 2, 2004 sounds like your auto-down function is sticking, or "down" is just sticking in general, which causes the breaker to trip, and after hitting "up" it unsticks and the breaker will reset in a minute or so. Long story short, try hitting "up" for a second, just after the window is all the way down, and see if it will act correct. I'd recommend anyway- replacing the switches. Quote
93CutlassSupreme Posted November 2, 2004 Author Report Posted November 2, 2004 sounds like your auto-down function is sticking, or "down" is just sticking in general, which causes the breaker to trip, and after hitting "up" it unsticks and the breaker will reset in a minute or so. Long story short, try hitting "up" for a second, just after the window is all the way down, and see if it will act correct. I'd recommend anyway- replacing the switches. i highly doubt they're still avaiable new. anyone know Quote
Brian P Posted November 3, 2004 Report Posted November 3, 2004 New? Maybe. You'd be surprised how much GM keeps around. But I'd say try a used one. Quote
93CutlassSupreme Posted November 3, 2004 Author Report Posted November 3, 2004 New? Maybe. You'd be surprised how much GM keeps around. But I'd say try a used one. if it becomes a major problem i'll work something out. i've called dealers for a few parts and they've been discontinued so the yard may be my only source Quote
dsgrntld187 Posted November 3, 2004 Report Posted November 3, 2004 My moms used to do that, and my dads Cavalier does it too. We always just press up when it gets to the bottom. It does that once in a while on my right rear window too. Quote
