5sp gp Posted October 30, 2004 Report Posted October 30, 2004 what brand of clutch do you guys recomend for my gp. it is all stock so i don't need a high performance one. i don't want to pay for a new gm clutch. Quote
Guest TurboSedan Posted October 30, 2004 Report Posted October 30, 2004 Luk Rep-Set. they cost $160 from a local shop for the '90 GP 3.1/5-speed application. get the flywheel resurfaced too, that will probably only cost another $15. proabably a good time to replace the rear main seal if it's leaking... Quote
5sp gp Posted November 5, 2004 Author Report Posted November 5, 2004 i got the clutch. does anyone know what the torque specs are for the flywheel and pressure plate and should i use any loctite on them Quote
Justin Posted November 5, 2004 Report Posted November 5, 2004 Flywheel To Crankshaft Bolt 52 ft.lb Clutch Cover To Flywheel 21 ft.lb I guess it couldn't hurt to use loctite, but it's not required. These specs are for a 1991 model year 3.1 W body. Quote
Guest TurboSedan Posted November 5, 2004 Report Posted November 5, 2004 Flywheel To Crankshaft Bolt 52 ft.lb Clutch Cover To Flywheel 21 ft.lb I guess it couldn't hurt to use loctite, but it's not required. These specs are for a 1991 model year 3.1 W body. i use red loc-tite on the flywheel-to-crank bolts as well as the pressure plate-to-flywheel bolts. make sure you tighten the bolts evenly in a criss-cross pattern; you don't want to warp anything. Quote
5sp gp Posted November 5, 2004 Author Report Posted November 5, 2004 thanks i will use loctite just to be safe the car is a 89 and has hard shifting problems so i hope this helps Quote
Guest TurboSedan Posted November 5, 2004 Report Posted November 5, 2004 Flywheel To Crankshaft Bolt 52 ft.lb Clutch Cover To Flywheel 21 ft.lb btw, my Haynes manual lists the same torque specs and those are the torque specs i have always used. fwiw i've never had a bolt come loose. the hard shifting might be due to air in the hydraulic system (clutch master/slave clyinders). good luck! Quote
Justin Posted November 6, 2004 Report Posted November 6, 2004 Check the fluid in your trans, sometimes if it gets really low you could have some hard shifting issues there as well. Quote
