Robby1870 Posted October 29, 2004 Report Posted October 29, 2004 I just replaced my turn signal switch about a month ago, and Im pretty sure its fried again, since I dont have brake lights once again (thats what was wrong the first time). I have a warranty on it for a year, but I'd like a fix-all solution, since, like las time, everything else turn signal switch related still works just fine. The only thing I can come up with is to splice the brake light wires together (the one that enters the turn signal switch and the one that exits it). But, none of my manuals (including my STE supplement) have a wiring diagram of the turn signal switch. So, I was wondering if anyone with a full set of factory manuals could give me a list of wire color/purpose for a turn signal switch with radio controls. Or, if you think this is a good/bad idea, maybe know why it has fried only the brake light part of the switch, or know of another reason my brake lights dont work, chime in, please. My 3rd brake light does work, so I know its the brake pedal switch and my tail lights work too. TIA Quote
DiscoStudd Posted October 29, 2004 Report Posted October 29, 2004 Okay, I admit I haven't tore into an 88-93 column before, but the Grand Prixes shouldn't have their brake lights run through the turn signal switch. They have the separate amber signals, therefore there's no reason to have the brake lights routed through the signal switch. If, for some odd reason, your car is wired that way, then rewire the lights so they go directly to the brake light switch (or even wire them to the 3rd brake light.) As far as wiring diagrams, hit up your local public library. Look up "Pontiac Grand Prix" in the card catalog, and head over to the reference section. There you'll find some gigantic manuals that have all kinds of wiring diagrams. Make some copies of the necessary info so you can take it home with you ... Quote
THe_DeTAiL3R Posted October 29, 2004 Report Posted October 29, 2004 I also find it strange how brake lights would be integrated with the signal light switch I've done it on both my 88' and my 95' GP. I know the switch controls the highbeams, 4-way flashers, (and those little wires for the radio buttons) although I have no idea what each individual wire actually does.. Quote
THe_DeTAiL3R Posted October 29, 2004 Report Posted October 29, 2004 Oh, doesn't the STE have backwards signal lights (in the back) with the brakes? Maybe there IS some difference there, I dunno. Quote
GnatGoSplat Posted October 29, 2004 Report Posted October 29, 2004 I would probably rewire it. It makes no sense on a Grand Prix for the brake lights to go through the turn signal switch. I don't see any reason for it. I have no idea why GM wired them that way. Quote
Robby1870 Posted October 29, 2004 Author Report Posted October 29, 2004 (or even wire them to the 3rd brake light.) Someone on this board did that, and since the 3rd brake light wire doesnt not need/have as many amps as the actual brake light wires, the brake lights were very dull. In fact, I think the person said the brake lights were BARELY brighter than the tails Quote
GnatGoSplat Posted October 29, 2004 Report Posted October 29, 2004 I wouldn't wire them to the 3rd brake light. I'd do a switch bypass under the dash. They will be dim through the 3rd brake light wire. It can't carry that much current by itself. Quote
Robby1870 Posted October 29, 2004 Author Report Posted October 29, 2004 I just drove the car around campus and my brakes lights worked fine, LOL. Fucking car. Maybe it just doesnt like running the lights on Thursdays. Quote
buckethead Posted October 29, 2004 Report Posted October 29, 2004 Sounds to me like a loose connection, check all the connections and grounds from the brake pedal on back. Quote
GnatGoSplat Posted October 29, 2004 Report Posted October 29, 2004 Nah, the loose connection is going to be in the turn signal switch. Jiggle it and watch your brake lights flicker. Quote
Brian P Posted October 30, 2004 Report Posted October 30, 2004 GM did it like that on the GP so they could use the same signal switch across the board. That's just the way it is, for some dumass reason. Quote
GnatGoSplat Posted October 30, 2004 Report Posted October 30, 2004 I don't think it could be the EXACT same switch though, because the red brake lights don't blink on the GP's. Quote
DiscoStudd Posted October 31, 2004 Report Posted October 31, 2004 They actually are the exact same switch on the "saginaw" columns (94-96.) On the saginaws, they have 2 different switches. One for cars with steering wheel controls, one for cars without them. No difference between the Grand Prixes and the other W's... Quote
Brian P Posted October 31, 2004 Report Posted October 31, 2004 I don't think it could be the EXACT same switch though, because the red brake lights don't blink on the GP's. They are. The wiring after the sinal switch is just different. I have a used signal switch from a Grand Prix in my sister's cutlass, plugged right in. Quote
GnatGoSplat Posted October 31, 2004 Report Posted October 31, 2004 Interesting, but even if they're exactly the same switch, they could have bypassed the turn signal switch for the brake lights, couldn't they? Quote
Brian P Posted October 31, 2004 Report Posted October 31, 2004 yes absolutely. There was no need for running the connection thru the switch. If I had a GP I may have just done it already, and not deal with signal switch vs brake light nightmares. Quote
