Speckkial Posted October 28, 2004 Report Share Posted October 28, 2004 What are signs that a tune-up is needed? Quote Link to comment Share on other sites More sharing options...
midnight rider Posted October 28, 2004 Report Share Posted October 28, 2004 poor response, week take off, iradic idle, lousy gas millage..... Quote Link to comment Share on other sites More sharing options...
5speedz34 Posted October 28, 2004 Report Share Posted October 28, 2004 Bad idle, misfiring, running rough....etc. Quote Link to comment Share on other sites More sharing options...
jeremy Posted October 28, 2004 Report Share Posted October 28, 2004 stalling....etc...etc.....etc.... Quote Link to comment Share on other sites More sharing options...
Speckkial Posted October 28, 2004 Author Report Share Posted October 28, 2004 Would it initiate the "service engine soon" light? I guess what I'm saying is, this light is lit on my car and I'm trying to figure out what could be wrong with it. Hell, I just bought the car Monday. Quote Link to comment Share on other sites More sharing options...
MyPrideandJoy Posted October 28, 2004 Report Share Posted October 28, 2004 What year is it? Motor? I have a 96' CS 3.1 SFI nevermind :oops: Quote Link to comment Share on other sites More sharing options...
jeremy Posted October 28, 2004 Report Share Posted October 28, 2004 take it to an autozone so they can pull the code for you.... Quote Link to comment Share on other sites More sharing options...
MyPrideandJoy Posted October 28, 2004 Report Share Posted October 28, 2004 take it to an autozone so they can pull the code for you... I'll run to autozone. Thanks. The check engine light is probably on bevause you said you had a bad O2 sensor. The SES lite doesnt come on to show a tune up, means a sensor has gone bad .. Quote Link to comment Share on other sites More sharing options...
terryk2003 Posted October 28, 2004 Report Share Posted October 28, 2004 take it to an autozone so they can pull the code for you... I'll run to autozone. Thanks. The check engine light is probably on bevause you said you had a bad O2 sensor. The SES lite doesnt come on to show a tune up, means a sensor has gone bad .. not TOTALLY TRUE!...the SES light will come on if there is a misfire detected...a bad plug or wire could cause a misfire and set the light oFF! Quote Link to comment Share on other sites More sharing options...
HokemBokem Posted October 28, 2004 Report Share Posted October 28, 2004 take it to an autozone so they can pull the code for you... I'll run to autozone. Thanks. The check engine light is probably on bevause you said you had a bad O2 sensor. The SES lite doesnt come on to show a tune up, means a sensor has gone bad .. It can mean a lot Quote Link to comment Share on other sites More sharing options...
Dannymik Posted October 28, 2004 Report Share Posted October 28, 2004 take it to an autozone so they can pull the code for you.... If you don't have a Autozone I think Advanced Auto does it also, and its for free Quote Link to comment Share on other sites More sharing options...
93CutlassSupreme Posted October 29, 2004 Report Share Posted October 29, 2004 take it to an autozone so they can pull the code for you... I'll run to autozone. Thanks. The check engine light is probably on bevause you said you had a bad O2 sensor. The SES lite doesnt come on to show a tune up, means a sensor has gone bad .. not TOTALLY TRUE!...the SES light will come on if there is a misfire detected...a bad plug or wire could cause a misfire and set the light oFF! not always. i've had quite a few very noticable misfires over the time i've owned this beast and i've never had a SES light. Quote Link to comment Share on other sites More sharing options...
cutlassdude96 Posted October 29, 2004 Report Share Posted October 29, 2004 take it to an autozone so they can pull the code for you... I'll run to autozone. Thanks. The check engine light is probably on bevause you said you had a bad O2 sensor. The SES lite doesnt come on to show a tune up, means a sensor has gone bad .. not TOTALLY TRUE!...the SES light will come on if there is a misfire detected...a bad plug or wire could cause a misfire and set the light oFF! not always. i've had quite a few very noticable misfires over the time i've owned this beast and i've never had a SES light. OBDII cars it does Quote Link to comment Share on other sites More sharing options...
terryk2003 Posted October 29, 2004 Report Share Posted October 29, 2004 take it to an autozone so they can pull the code for you... I'll run to autozone. Thanks. The check engine light is probably on bevause you said you had a bad O2 sensor. The SES lite doesnt come on to show a tune up, means a sensor has gone bad .. not TOTALLY TRUE!...the SES light will come on if there is a misfire detected...a bad plug or wire could cause a misfire and set the light oFF! not always. i've had quite a few very noticable misfires over the time i've owned this beast and i've never had a SES light. OBDII cars it does yeah...i guess i shoulda mentioned that...but i figured if people actually READ what kind of car he had...being that its a '96 they would know that its OBDII.. ...and YES OBDII DOES do that! Quote Link to comment Share on other sites More sharing options...
93CutlassSupreme Posted October 29, 2004 Report Share Posted October 29, 2004 take it to an autozone so they can pull the code for you... I'll run to autozone. Thanks. The check engine light is probably on bevause you said you had a bad O2 sensor. The SES lite doesnt come on to show a tune up, means a sensor has gone bad .. not TOTALLY TRUE!...the SES light will come on if there is a misfire detected...a bad plug or wire could cause a misfire and set the light oFF! not always. i've had quite a few very noticable misfires over the time i've owned this beast and i've never had a SES light. OBDII cars it does yeah...i guess i shoulda mentioned that...but i figured if people actually READ what kind of car he had...being that its a '96 they would know that its OBDII.. ...and YES OBDII DOES do that! his first post doesn't say what car he has Quote Link to comment Share on other sites More sharing options...
