GnatGoSplat Posted September 10, 2002 Report Posted September 10, 2002 Anyone know how to tighten up the throttle on a '94 3.4 DOHC? It's so loose I can't even feel myself pressing on the pedal. Quote
Guest Anonymous Posted September 10, 2002 Report Posted September 10, 2002 Maybe the cable is stretched from someone trying to push the pedal through the floor. I actually don't think it's adjustable. Quote
TGPilot Posted September 10, 2002 Report Posted September 10, 2002 Sprinkle some dirt on it....that should get it good and stiff for you! hehe j/k I have no idea... 8) Quote
Guest Anonymous Posted September 10, 2002 Report Posted September 10, 2002 Sprinkle some dirt on it....that should get it good and stiff for you! I'm not even going to touch that statement! Quote
GnatGoSplat Posted September 10, 2002 Author Report Posted September 10, 2002 Sprinkle some dirt on it....that should get it good and stiff for you! hehe j/k I have no idea... 8) :fruity: No thanks. I don't think it's loose from slack because the throttle moves, it just has no springiness at all. Quote
Guest Anonymous Posted September 10, 2002 Report Posted September 10, 2002 Is it real bad? Check the spring on the back of the pedal arm where the cable connects. If it's wore out or gone that would give some slack. Also the arm in the throttle body could be wearing out. MAYBE I don't even know if those wear out. Turn the throttle cam by hand and see how much spring back it has. Or disconnect the cable from the pedal and see how much spring it has to it. Not sure if I have any idea what I'm talking about as I have just got home from working midnights. I'm just trying to help you out. Quote
