Guest Posted January 4, 2003 Report Posted January 4, 2003 my turbo has bean rebuilt and whoever did it put a bent up genaric actuator on my turbo and i think its messing up my car when i accelerate. So i was wondering if these things are sold often or if i can by a good gm one or something that will make my car run better. Quote
90TGP Posted January 4, 2003 Report Posted January 4, 2003 The guy that did the 5-speed swap into the TGP bought a GM actuator. Quote
Chris A Posted January 4, 2003 Report Posted January 4, 2003 I can't say I have a good answer for that. I tried to buy one once, called the dealer, no luck, called around to a bunch of turbo rebuilders, no luck. So hopefully someone will have better insight. Quote
TGPilot Posted January 5, 2003 Report Posted January 5, 2003 Call these folks and tell them what you want. They have an adjustable waste gate actuator you may like. I do not have part numbers sorry. http://www.turboengineering.com/ 8) Quote
SleeperRed90TGp Posted January 6, 2003 Report Posted January 6, 2003 I got mine from the people below, $90.00. It's the stock replacement but will only hold about 10# of boost. I have to put springs on the wastegate to get more. These people have everything you can imagen for a turbo and were very helpful. WASTE GATE P/N M & D DISTRIBUTOR 430727 6931 NAVIGATION 3198 HOUSTON TX 77011 22757 746-923-2476 Quote
iTurbo Posted January 6, 2003 Report Posted January 6, 2003 http://www.relentlessracing.com has them for T3 and T4 turbos. I'm not sure if they can get them for T25s. Look in the DIY section, or just email him. Quote
RedZMonte Posted January 7, 2003 Report Posted January 7, 2003 Call these folks and tell them what you want. They have an adjustable waste gate actuator you may like. I do not have part numbers sorry. http://www.turboengineering.com/ 8) I buy ALLOT of stuff through them for various things. they are a Great source for parts, my T04E is actually built by them. Turbonetics was taking too long so i got one from them. they also rebuild turbo's and can adjust the AR and every aspect of the trubo. I would like to see a TGP try a T25/T28 or T25/T3 to see the outcome of it. it would give a larger CFM rating on the intake side and should make a nice chunk of power. RedZ Quote
