stockgp Posted October 27, 2004 Report Share Posted October 27, 2004 are 90 and 93 gp clusters different? i plugged my 90 cluster into my 93 harness and it's not working. Quote Link to comment Share on other sites More sharing options...
Robby1870 Posted October 27, 2004 Report Share Posted October 27, 2004 like nothing's turning on? Which clusters are we talking about here? Base, full gauges, digital? Quote Link to comment Share on other sites More sharing options...
stockgp Posted October 27, 2004 Author Report Share Posted October 27, 2004 like nothing's turning on? Which clusters are we talking about here? Base, full gauges, digital? full gauges from a 90 gp. yeah nothing works Quote Link to comment Share on other sites More sharing options...
jeremy Posted October 27, 2004 Report Share Posted October 27, 2004 I always though that they were the same....did you turn the car on? Quote Link to comment Share on other sites More sharing options...
digitaloutsider Posted October 27, 2004 Report Share Posted October 27, 2004 The cluster should plug directly in and work. I'm running a '93 cluster in my car. The only different is aesthetic.. the oil pressure gauge doesn't have actual numbers on it, and the tachometer goes up to 8k instead of 7k. Quote Link to comment Share on other sites More sharing options...
stockgp Posted October 27, 2004 Author Report Share Posted October 27, 2004 I always though that they were the same....did you turn the car on? nope i was hopong magically it would work while the car's off. i kid. yeah the only thing that happens is the temp gauge goes up to 260, and the ses light works Quote Link to comment Share on other sites More sharing options...
Dirty Rockstar Posted October 27, 2004 Report Share Posted October 27, 2004 Are you changing from a base cluster or a Digital one? Maybe there are subtle differences.. Or the newer cluster is fucked up.. Never know.. Good luck and keep us aprised of any developments! Quote Link to comment Share on other sites More sharing options...
stockgp Posted October 27, 2004 Author Report Share Posted October 27, 2004 Are you changing from a base cluster or a Digital one? Maybe there are subtle differences.. Or the newer cluster is fucked up.. Never know.. Good luck and keep us aprised of any developments! no this is the cluster that was always in my car.it's from my 90. it's not working with the 93 dash harness i put in Quote Link to comment Share on other sites More sharing options...
Dirty Rockstar Posted October 27, 2004 Report Share Posted October 27, 2004 But the 93 one works, correct? Check the pinouts.. Maybe they arent backward compatable? Quote Link to comment Share on other sites More sharing options...
digitaloutsider Posted October 27, 2004 Report Share Posted October 27, 2004 Are you sure you didn't fuck up the dash harness somewhere? Edit: Also, are you sure you're pushing in the connector in all the way? Quote Link to comment Share on other sites More sharing options...
stockgp Posted October 27, 2004 Author Report Share Posted October 27, 2004 But the 93 one works, correct? Check the pinouts.. Maybe they arent backward compatable? don't have the one from the 93. Are you sure you didn't fuck up the dash harness somewhere? Edit: Also, are you sure you're pushing in the connector in all the way? nope harness is good, yes connector is in all the way. Quote Link to comment Share on other sites More sharing options...
jeremy Posted October 28, 2004 Report Share Posted October 28, 2004 did you figure this out yet? Quote Link to comment Share on other sites More sharing options...
no1kicker Posted October 28, 2004 Report Share Posted October 28, 2004 I can get you the cluster pinout for the 90 if that helps. Quote Link to comment Share on other sites More sharing options...
stockgp Posted November 2, 2004 Author Report Share Posted November 2, 2004 nope haven't figured it out yet. pinouts from the 90 might help[ some. thanks Quote Link to comment Share on other sites More sharing options...
