stockgp Posted October 26, 2004 Report Posted October 26, 2004 there's a metal line under the brake booster that runs under the the car with the brake lines. if i remember correctly there was a rubber hose on it? anyways, the hose i missing and i assume that line is there for a reason. is it some kind of vacuum line? Quote
1990lumina Posted October 26, 2004 Report Posted October 26, 2004 I'm just guessing, but if it was just over the metal line it may have ben some sort of protection from heat, just a guess though... - Jeff L. Quote
Brian P Posted October 27, 2004 Report Posted October 27, 2004 that may be the canister purge line, the canister is by the gas tank. See if the line has been cut. Quote
stockgp Posted October 27, 2004 Author Report Posted October 27, 2004 from what i can see it's not cut. it just terminates under the brake master cylinder. Quote
Brian P Posted October 27, 2004 Report Posted October 27, 2004 yeah, get a piece of hose for that line, and run it to the canister purge solenoid (get a good hose, like fuel supply quality) Quote
stockgp Posted October 27, 2004 Author Report Posted October 27, 2004 yeah, get a piece of hose for that line, and run it to the canister purge solenoid (get a good hose, like fuel supply quality) ok i will thanks Quote
