Weird Problem with CS
Today it happened to me 3 times , when i was turning it felt like my power steering stoped working for a second and a Check Gauges light came up but that only happened for about 1-3 seconds and then no problem what could cause that? I would think that ESS light would come up not Check Gauges light so now i am clueless what might be wrong. :cry:
I haven't gotten the check engine light or check guages yet, but I have had the same thing happen. I think the RPM's aren't up high enough, and it is drawing too much power... thus causing the rpms to drop even lower which sends the single to "check guages".... just my two cents..
you might be right because when that happened i thought that my car died and when that happens you loose a power steering but it didnt die so that may be the problem, my car will be at the mechanic next week i think i will mention that to him because its a little weird and annoying because i almost had an accident because of that.
