90TGP Posted October 25, 2004 Report Posted October 25, 2004 I just replaced the brakes on my TGP with the cross-drilled rotors and new brake pads. A friend of mine did it for me. Ok, before I had the brakes replaced, the pedal went closer to the floor then usual [because the previous owner replaced the ABS brakes with vacuum brakes.]. Both rear calipers were replaced a year ago. The car stoped fine, and I was used to the brakes. After the brake job, the pedal goes down even further now, and I get a weird sound coming from the pedal? It sounds like air in liquid? I'm thinking of getting the brakes bleeded. What could be the problem? I don't think my friend removed the calipers from the lines. Quote
Dirty Rockstar Posted October 25, 2004 Report Posted October 25, 2004 Didnt you know W body brakes SUCK??? LOL.. jk.. Try bleeding them.. That may be all it needs.. Thats the place I would start.. I had that problem everytime I did the brakes in my 6000.. Good luck! Quote
HokemBokem Posted October 25, 2004 Report Posted October 25, 2004 Bleed them bitches then tell us if the problem persists Quote
midnight rider Posted October 25, 2004 Report Posted October 25, 2004 you've got air in your brake lines or you are out of or low on fluid in the master cylinder. Blead your brakes and you should be alright. Quote
