That elusive firewall gromet
Ok is this the place where I should route my 4ga wire? I'd like to finally get this done lol.
I've had no problem getting through that gromet on both my cars.. I'm sure there are many other cars out there that don't have as nice a spot.
When I installed fog lights on my chrysler, I had no good spots to run the wire through the firewall, so i had to make one, except I didn't have a drill, so i grabbed a screwdriver and found a rusty spot on the fire wall and was able to poke right through it... perfecto! Also, I didn't put in a gromet to protect it... I think i must have burnt out the fuse 3 or 4 times before it wouldn't work at all anymore, I'm a mechanical GENIUS!!!
i assume thats the one close to the steering wheel. yeah its good! for future reference, don't run more than at least 2 more wires through it(18gauge) and DONT USE A COAT HANGER!!! :lol: see what happened when i used one!(that gromet was crowded by a 4g and other wires)
Strange, on my car the grommet is something like 1-1/2" in diameter and a ton of wires fit through it with no problem. I just took a pocket knife and slit an "X" in it and pushed all my wires through, no problem. I even stuck my finger through and there were no sharp edges to hurt the wires. I don't know what I did different?
i used to have the 4g sub wire going through w/ like 3-5 14-18g wires, till they melted to the gromet, and had to be cut. now just 3 14-18g running through.
Thats the same thing im going to do when I get my system in December.
i just ripped that little thing out. it was not held in tight enough for me to slide wire through it without it popping out itself. and no i do not get water inside of my car unless im 4 wheeling through some major mudholes (which does NOT happen anymore!)
