HokemBokem Posted October 24, 2004 Report Share Posted October 24, 2004 Have you guys ever tried the bosch platinum spark plugs? http://www.boschusa.com/AutoParts/SparkPlugs/Platinum/ I just picked 6 of them up yesterday at checker for only 13 bucks! They said that if you dont feel a difference that Bosch will pay for the plugs. Also when you gap the plugs should the gapper be able to pass through without touching or squeeze in tight when at the right setting? Quote Link to comment Share on other sites More sharing options...
Guest Anonymous Posted October 24, 2004 Report Share Posted October 24, 2004 When gapped right, there should be a slight drag on the gapper. Quote Link to comment Share on other sites More sharing options...
terryk2003 Posted October 24, 2004 Report Share Posted October 24, 2004 When gapped right, there should be a slight drag on the gapper. :withstupid: ...but, i HIGHLY doubt that changing to these plugs is gonna make a noticeable difference unless you're plugs are totally SHOT!!...i mean, i dunno about you're car...but mine had PLATINUM AC DELCO's in it from the factory, so i don't think you're really upgrading much...just mY oPinIoN...BUT...let us know if you FEEL the difference Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted October 24, 2004 Report Share Posted October 24, 2004 I'd return 'em right now before you even waste the time installing them. Bosch plugs run like shit in these cars. I've tried them in two 3100's and a 3800.. worst thing I'd ever done. Stick with ACDelco. Quote Link to comment Share on other sites More sharing options...
HokemBokem Posted October 24, 2004 Author Report Share Posted October 24, 2004 I'd return 'em right now before you even waste the time installing them. Bosch plugs run like shit in these cars. I've tried them in two 3100's and a 3800.. worst thing I'd ever done. Stick with ACDelco. The guy at checker said these were the closest to AC Delco's they had. Can anyone else verify that they will run like shit? Im only changing them btw because my car has 92,000 miles on it and has never had a spark plug change. Quote Link to comment Share on other sites More sharing options...
gp90se Posted October 24, 2004 Report Share Posted October 24, 2004 do NOT put the bosch plugs into your motor, period. lower MPG, lower performance, and much higher chance of fouling. if they dont have delcos, go with either champions or splitfires. ill say it again, DO NOT put bosch into ANY GM vehical. Quote Link to comment Share on other sites More sharing options...
slick Posted October 24, 2004 Report Share Posted October 24, 2004 I've heard these plugs are not good in GM's by several people. Aparantly the vehicle runs like total garbage. Quote Link to comment Share on other sites More sharing options...
HokemBokem Posted October 24, 2004 Author Report Share Posted October 24, 2004 Wow well that sucks ass. Will checker take them back even if I have opened one of the boxes? I guess I will leave in a little bit to take them back if they do. Quote Link to comment Share on other sites More sharing options...
gp90se Posted October 24, 2004 Report Share Posted October 24, 2004 ya they should take em back, goto another parts store and find either delcos are delco rapidfires. While ya spending the $ (saving a bunch returning the junker plugs) spend $35 on the delco O2 sensor. Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted October 24, 2004 Report Share Posted October 24, 2004 I'd return 'em right now before you even waste the time installing them. Bosch plugs run like shit in these cars. I've tried them in two 3100's and a 3800.. worst thing I'd ever done. Stick with ACDelco. The guy at checker said these were the closest to AC Delco's they had. Can anyone else verify that they will run like shit? Im only changing them btw because my car has 92,000 miles on it and has never had a spark plug change. I work at Checker, man.. I'd NEVER recommend Bosch plugs for almost any GM product. Sheee.. I'd run an Autolite over the Bosch. ACDelco would be the only way I'd go. Quote Link to comment Share on other sites More sharing options...
DiscoStudd Posted October 24, 2004 Report Share Posted October 24, 2004 Champions and Autolites (platinum) actually perform fairly well on a GM Waste-Spark system. I put a set of NGK's in the Lumina recently, and I'm not that impressed (I'm switching back to Rapidfires soon...) Bosch Platinums (especially the +2's and +4's) supposedly burn out the coil packs because they cause them to overheat. I can't verify that, but there are tons of people that tell you to stear clear of them. Just stick to AC Delco plugs to be on the safe side... Quote Link to comment Share on other sites More sharing options...
DaveFromColorado Posted October 24, 2004 Report Share Posted October 24, 2004 I use RapidFire plugs in my GM's and I've always been happy with them. time after time I've seen the Bosch platnum's go bad too quickly. --Dave Quote Link to comment Share on other sites More sharing options...
JoroCorona Posted October 24, 2004 Report Share Posted October 24, 2004 I'm using Autolite Double Platinums and they work really well. Or its the fact that I changed the intake at the sametime as the plugs cause it gave me alittle boost in performance. Quote Link to comment Share on other sites More sharing options...
WhiteOut Posted October 24, 2004 Report Share Posted October 24, 2004 Return the Bosh plugs. I've tried them multiple times, in a 3800 Series I, an Supercharged 3800 Series II, and my 3.4 DOHC and every time they've fouled out around 20k miles. Usually they get so bad its to the point where the car will barely run right. In fact my 3.4 was only running on 3 cylinders due to bad BOSCH plugs, which caused my cat to die because of fuel poisoning. Its not the fact that the plugs are total crap, because they aren't. GM just happens to use a waste spark ignition system which these plugs just aren't designed to deal with. My advice to you is to take those plugs back and find the Rapid Fire #8 AC Delco plugs. They won't cost anymore and they work great. Quote Link to comment Share on other sites More sharing options...
sl3196 Posted October 24, 2004 Report Share Posted October 24, 2004 I bosch plugs in my old cutlass, they burnt up quick. Put some autolight double platnium in there and they never gave me trouble. I would probaly just go get some ac delco plugs. Quote Link to comment Share on other sites More sharing options...
HokemBokem Posted October 24, 2004 Author Report Share Posted October 24, 2004 I just got back from returning them and the Oil Treatment. Do you guys know if AutoZone or Napa carries AcDelco becasue the only stores around me are Checker Autozone and Napa. Also how much do AcDelco's cost a piece? Quote Link to comment Share on other sites More sharing options...
sl3196 Posted October 24, 2004 Report Share Posted October 24, 2004 I think only the dealer has ac delco, could be wrong though. Quote Link to comment Share on other sites More sharing options...
sl3196 Posted October 24, 2004 Report Share Posted October 24, 2004 Shit double post. Stupid work computer! Quote Link to comment Share on other sites More sharing options...
HokemBokem Posted October 24, 2004 Author Report Share Posted October 24, 2004 Yea and the dealer bends you over with charges Quote Link to comment Share on other sites More sharing options...
sl3196 Posted October 24, 2004 Report Share Posted October 24, 2004 Charges? All your getting is the parts right? I think they are like $7-$8 a piece but not sure. Quote Link to comment Share on other sites More sharing options...
rudefyet Posted October 24, 2004 Report Share Posted October 24, 2004 autozone carries Delco parts i'm getting ready to go pick up a set of rapidfires right now Quote Link to comment Share on other sites More sharing options...
HokemBokem Posted October 24, 2004 Author Report Share Posted October 24, 2004 8 bucks a piece! damn the bosch platinums were 1.99 a piece. Quote Link to comment Share on other sites More sharing options...
rudefyet Posted October 24, 2004 Report Share Posted October 24, 2004 they're $4.49 a piece at autozone for rapidfires regulars are just $1 something Quote Link to comment Share on other sites More sharing options...
HokemBokem Posted October 24, 2004 Author Report Share Posted October 24, 2004 they're $4.49 a piece at autozone Thats better Quote Link to comment Share on other sites More sharing options...
supreme_style21 Posted October 24, 2004 Report Share Posted October 24, 2004 Advance Auto carries Delco as well. I got mine at a local AC distributor.. $1.60 per plug and $21 for a set of Delco wires. Quote Link to comment Share on other sites More sharing options...
