well the Lumina broke...(Updated w/pics)
on my way home, felt like I hit something, got out, everything was fine...
turns out the drivers side strut assembly snapped. melted my tire because of rubbing...shit
I need to know my morning if the springs on a 92 Euro 3.4 are any different from my 90 Euro 3.1?
The Euro3.4 has FE3, but isn't that just swaybar difference?
Thankz guyz and wish me luck!
it'll all bolt up, might ride a bit different though if it's a different stiffness than everything else on there..
it wont hurt to put the drivers side assembly on for now and do the other when you can. i had FE3 assemblies from a gutlass 3.4 - threw the drivers side in my sister's base FE1 lumina, car was just fine, put 15k on it and never bothered doing the other side.
so the spring is stiffer than the FE1 spring. it won't throw the alignment off or anything? I just will have better cornering on one side 8)
like others have said, take both front springs so you have an even springrate in the front end. Also, if you can pull the monoleaf from the rear, you'll want to do that to.
it's probably also about time for new struts in the front at least - maybe rears too just to keep the whole car balanced.
you'll need an alignment after you replace all that stuff.
--Dave.
http://www.w-body.com/index2.html
if you look at the chart my car had FUX springs on it now the drivers front has the CJK spring on it and the passenger still has the FUX spring.
I will eventually put the other side on but, it rides nice, so I will leave it for now.
pics soon...boy the strut assembly was destroyed
I personally would swap both fronts but I don't think that you will notice a difference if you only swap one....
it corners like a mother fucker around right turns 8)
the left hand turns inproved too
I will eventually change the other one over
Nice!! Sets lower than mine or Jay's lumina's!!
that is exactly what I was thinking......
i guess thats what ya get DON for thinking it's a race car! lol jk
glad to see no one was hurt, but it does look pretty cool with NO wheel gap !!! LMFAO :lol:
yeah don, we know your a racer. j/k
it did look prety badass with no wheel gap though
I had a simular thing happen last year the d-side front spring plate on my cutty rusted out, the whole thing fell right on the tire. Luckily I was only going 15mph. Where exactly did yours break?
