need some info on the getrag 282 where the cables connect
the trans i have is missing the inserts where the cables go. does anyone know how to get new ones
Check with Canada on here, he knows a guy that makes the polyurethane inserts. There was a topic on here about it as well, do a search.
pictures would be great so would part numbers. it is the trany end. I am getting real close now just trying to get the last stuff
Guest TurboSedan
huh i'm still confused as to which part you're talking about...
...jegs :lol:
on the trans there is the brackets for the cables...on the brackets are the mountings for the cables. i need what the cbales mount onto....i am at it need 282 shift cables too
oh well i will call the local dealer and see if they could help me out
what is the vin for your car i need one to give to them other wise they wont look it up
Guest TurboSedan
i will check around to see if i have any. i'm almost postitive i have one but only one.
but if you do get a pair of W-body 282 cables later from a j/y, they should be included with them like Davis said.
NO JEGS DOSEN"T HAVE THESE!!!
This Guy is just a Useless "member"
I was just kiddin around man jeeze :lol:
I'm pretty sure Beretta's and Cavi's from 88-93 or so use the same pieces. I think that was where I got one from, I've got a bunch sitting around now.
