HokemBokem Posted October 20, 2004 Report Posted October 20, 2004 sorry about this question but i just wanted a quick answer, if my tires say the limit is 35 psi should i fill them up to 35 or a little lower? Ive seen some wear on the sides of my brand new tires that i think could be from underinflation???? what do you guys think Quote
DaveFromColorado Posted October 20, 2004 Report Posted October 20, 2004 Whelp, on the inside of your trunklid, or on the the inside of the doorjam or the door itself (on the sticker by the lock mechanism) there should be a listing of what GM wants you to set the tire pressure at. Typically, I run mine to the max on the tire - but for a smoother softer more comfortable ride, set them to what GM wants. --Dave. Quote
HokemBokem Posted October 20, 2004 Author Report Posted October 20, 2004 well all the tires are differant then when I bought the car Quote
Dirty Rockstar Posted October 20, 2004 Report Posted October 20, 2004 Well, since the tires are all different, then you'dwant to run them at what GM wants.. Because they all prolly contain the air a little differently compared to eachother, and their Max. PSIs aree prolly different.. God.. I hate tires.. Quote
WhiteOut Posted October 20, 2004 Report Posted October 20, 2004 God.. I hate tires.. So you would prefer what....Flintstone style rock wheels? Just kidding man, I couldn't pass that one up. Seriously though, I'd just set all four tires to 32 psi and call it good. Quote
Dirty Rockstar Posted October 20, 2004 Report Posted October 20, 2004 I ru my tires at 35 PSi.. I like the stiffer ride.. Altrhough the blown struts in the back bounce a hell of a lot more like that.. lol Quote
THe_DeTAiL3R Posted October 20, 2004 Report Posted October 20, 2004 32,34... different shops do it differently I know that. I set mine to 35psi right now but might go a bit lower when the snow comes. Quote
HokemBokem Posted October 20, 2004 Author Report Posted October 20, 2004 Yea i think this morning i will go set them all to 32. Thanks for the input guys. Quote
DiscoStudd Posted October 20, 2004 Report Posted October 20, 2004 Altrhough the blown struts in the back bounce a hell of a lot more like that.. lol I can relate to that! My struts and mounts are gone on my Regal. It's KYB time pretty soon here! I usually fill mine up to 40 no matter what kind of car it is. I prefer the slight bit of handling improvement over a softer ride. I wouldn't go less than 32 regardless of what the sticker says... Quote
GnatGoSplat Posted October 20, 2004 Report Posted October 20, 2004 You can inflate to whatever you want, so long as it's AT or ABOVE manufacturer recommended pressure and BELOW tire max pressure. Car manufacturer recommended pressure takes into account: OEM tire size/design, comfort, handling, wear, and compromises between them all. In fact, sometimes the car manufacturer recommends a different pressure than the tire manufacturer. Firestone claimed Explorers suffered blowouts because Ford recommended lower pressure than Firestone recommended. Anyway, it's better to err on the high side. An underinflated tire can lead to blowout which can and have caused accident, injury, and death. Quote
pitzel Posted October 20, 2004 Report Posted October 20, 2004 40psi here on Firestone P215/75R15 tyres. On the highway, I've achieved 40mpg in this car on the 1000 mile highway trips, so I must be doing something right with respect to the tyres. Quote
Black Adam Posted October 21, 2004 Report Posted October 21, 2004 You can inflate to whatever you want, so long as it's AT or ABOVE manufacturer recommended pressure and BELOW tire max pressure. Anyway, it's better to err on the high side. An underinflated tire can lead to blowout which can and have caused accident, injury, and death. he's absolutely correct this is one of the few things i know about cars also underinflated causes your gas mileage to go down Quote
HokemBokem Posted October 21, 2004 Author Report Posted October 21, 2004 well there all at 35 and thats there max psi but the front 2 look kinda low? They look like they need some air, or is that normal??? Quote
DiscoStudd Posted October 21, 2004 Report Posted October 21, 2004 Don't judge by how they look (unless they're obviously waaaaaay flat,) go by what your pressure gauge tells you. The gauge is always more accurate than your eyes are... Quote
HokemBokem Posted October 21, 2004 Author Report Posted October 21, 2004 Yea im keepin them like that, i just thought it was wierd that it looked a little flat still. But my buick feels very smooth now with those new rotors pads and all new tires Quote
midnight rider Posted October 21, 2004 Report Posted October 21, 2004 32 to 35 is the general rule for all car tires ie P rated, 35 to 40 on light truck tires ie LT rated and under 50 psi for your bigger truck tires like AT rated tires. Air preasure also can cause differnces in gas millage. An under inflated tire will cause worse millage than one inflated properly, but will make the ride of the vehicle softer and can be used as a quick alignment fix. It will also increase traction. Some dealers do stuff like that. Over inflated tires will make the car roll easier but it will ride rough as hell. A car with a slipping trans won't slip as bad if the tires are inflated 10 psi over what they should be because less of the area of tread touches the ground creating less friction. You can not eyeball a tire and tell if it is inflated properly. You must use a gauge. The main reason your front tires look flat is beacuse there is more weight on them than there is on the back tires. I hope this has answered a few questions about this subject for everyone. Quote
HokemBokem Posted October 21, 2004 Author Report Posted October 21, 2004 32 to 35 is the general rule for all car tires ie P rated, 35 to 40 on light truck tires ie LT rated and under 50 psi for your bigger truck tires like AT rated tires. Air preasure also can cause differnces in gas millage. An under inflated tire will cause worse millage than one inflated properly, but will make the ride of the vehicle softer and can be used as a quick alignment fix. It will also increase traction. Some dealers do stuff like that. Over inflated tires will make the car roll easier but it will ride rough as hell. A car with a slipping trans won't slip as bad if the tires are inflated 10 psi over what they should be because less of the area of tread touches the ground creating less friction. You can not eyeball a tire and tell if it is inflated properly. You must use a gauge. The main reason your front tires look flat is beacuse there is more weight on them than there is on the back tires. I hope this has answered a few questions about this subject for everyone. yes it has midnight rider, its nice your still helpin even tho you dont have a W Quote
midnight rider Posted October 21, 2004 Report Posted October 21, 2004 yes it has midnight rider, its nice your still helpin even tho you dont have a W I like to help when I can. I am a fountain of odd knowledge like that. I bet I'm probaly one of a few guys that can set a set of points with a matchbook and time a car by ear.....lol Quote
Dannymik Posted October 21, 2004 Report Posted October 21, 2004 well there all at 35 and thats there max psi but the front 2 look kinda low? They look like they need some air, or is that normal??? think about it, where's the most weight on your car? Thats why they look like they need more air. BTW I'm a 34-35 psi user. Quote
HokemBokem Posted October 21, 2004 Author Report Posted October 21, 2004 there all at 35 psi now Quote
