KING JOKER Posted October 17, 2004 Report Posted October 17, 2004 i have ac on my 1992 cutlass 2 door with the 3.1 . i wanted to know how to remove this and delete the ac if it is possible. can i do it and what all can i take off .any help would be appreciated. Quote
slick Posted October 17, 2004 Report Posted October 17, 2004 Yes, its possible. You will have to make a mount to mount an extra pulley to take up the lag for removing the AC. Quote
WhiteOut Posted October 18, 2004 Report Posted October 18, 2004 Piece of cake. Just remove the belt, remove the compressor and get a new belt meant for a 3.1 Beretta without A/C as an option. Quote
maybe2fast Posted October 18, 2004 Report Posted October 18, 2004 is the compressor bad? are you looking for more power by deleting? whats the deal? Quote
GnatGoSplat Posted October 18, 2004 Report Posted October 18, 2004 is the compressor bad? are you looking for more power by deleting? whats the deal? I think he's just clinically insane. Quote
digitaloutsider Posted October 18, 2004 Report Posted October 18, 2004 And less drag on the entire system. My compressor broke a while back and I'm too lazy to fix it. Still am.. I just put a smaller belt on. Quote
KING JOKER Posted October 18, 2004 Author Report Posted October 18, 2004 so just take it off and get a belt for a 3.1 without ac? Quote
maybe2fast Posted October 18, 2004 Report Posted October 18, 2004 you don't even have to remove the compressor if you don't want to! just put the new belt on Quote
Guest TurboSedan Posted October 18, 2004 Report Posted October 18, 2004 i'm removing AC for two reasons. less weight, and to make room for a nice FMIC Quote
Canada Posted October 18, 2004 Report Posted October 18, 2004 My roomate has a 1988 Beretta GTU (2.8L/5 speed)......the previous owner removed the A/C and simply ran a short belt from the crank to the power steering pump........htis BARELY gives enough belt to run the water pump. GM has a idler for the non-A/C cars......my roomate has the part number for this. When he gets back, I'll post it. Quote
citheman85 Posted October 19, 2004 Report Posted October 19, 2004 you can allways try looking in the junkyard i found one for $5 Quote
THe_DeTAiL3R Posted October 19, 2004 Report Posted October 19, 2004 you don't even have to remove the compressor if you don't want to! just put the new belt on Thanks for the tip!!!! Now I can drive to NAPA sometime and put one on in the parking lot, and if its the wrong size get another one. Quote
digitaloutsider Posted October 19, 2004 Report Posted October 19, 2004 you don't even have to remove the compressor if you don't want to! just put the new belt on Thanks for the tip!!!! Now I can drive to NAPA sometime and put one on in the parking lot, and if its the wrong size get another one. God, I've said this OVER AND OVER AND OVER AND OVER. Quote
THe_DeTAiL3R Posted October 19, 2004 Report Posted October 19, 2004 you don't even have to remove the compressor if you don't want to! just put the new belt on Thanks for the tip!!!! Now I can drive to NAPA sometime and put one on in the parking lot, and if its the wrong size get another one. God, I've said this OVER AND OVER AND OVER AND OVER. I know, but I thought I'd probalby have to take off the compressor.. Quote
digitaloutsider Posted October 19, 2004 Report Posted October 19, 2004 Why would you have to do that? Quote
