When the car's brakes are applied hard, the car pulls to the left. I have checked the front calipers and the right side caliper has play in the slide bolts. Should both the slide bolts and the bushings be replaced, or just the bushings? Also, do I have to remove the whole caliper just to replace the slide bushings?
Both bushings should be replaced for sure, and the slide bolts should be replaced if they show any sign of wear (such as corrosion, pitting, or discoloration from heat).
