Fiero Question...
an upper intake from a Fiero with the TB, I know it would bolt to my lower intake but will the TB hook up to my cables? Accelerator, and detant cable?
Guest BeausoleilRacing
I put a Holley TB on my Regal, I don't see why it wouldn't work on your car.
And where did you get this at??
They actually made a Holley TB for the Fiero's?!?!?!
IIRC: they came from the factory with them
Wow, I did not know that. Is it any larger than the FWD 3.1 TB's?
I don't remember how big it is..... :?
It's the same size as the aluminum headed 2.8/3.1 throttlebods.
Those little throttlebodies aren't that great. At high RPG them and the restrictive intake manifolds really suck ass.
I knew another fiero lover would chime in eventually :D
I thought the Fiero upper intake was better that the stock 3.1 upper intake
I doubt it, the upper intake on a fiero is actually quite restrictive....
okay...
-the Fiero intake will bolt right to my lower intake right?
-Will my 3.1 TB bolt to the Fiero intake so the vacuum ports will fit and everything
-Will I loose power with the Fiero intake? How restrictive could it be?
-I think with alittle work that intake will look awsome!
no one can answer my questions on page 1?
I wish I could....the only thing I can suggest is try it and let us know...
Why not ask on a Fiero board instead?
better off on the 60degree board, fieros never had a 3.1
Trust me here... take your pick of GM engines v8, I4, V6... The Fiero guys have done it. Plenty of 3.1 owners on the Fiero board.
I don't think the upper intake is a bolt on. I am pretty sure you have to do the lower intake too, and even then I am not sure if that will work due to the heads. The 2.8 in the Fiero , have iron heads not aluminum......
http://www.fiero.nl/cgi-bin/fiero/Ultimate.cgi?action=intro
