z34_nut Posted October 13, 2004 Report Posted October 13, 2004 kinda confused, i think its a vaccum, i'm not getting any vaccum to my cruise control modular. also my motor for my heater works, it just makes alot of nioce, but nothing comes out of the vents, just happened today? what vaccums can i look for other then the ones in the back of the plenum? Quote
slick Posted October 13, 2004 Report Posted October 13, 2004 Look right underneath the cruise control module. Driver side. Should be a bunch of really small vacuum lines. Make sure there all plugged in. Quote
digitaloutsider Posted October 13, 2004 Report Posted October 13, 2004 The Check valve is probably broken. $7 dealer part. Quote
z34_nut Posted October 13, 2004 Author Report Posted October 13, 2004 Look right underneath the cruise control module. Driver side. Should be a bunch of really small vacuum lines. Make sure there all plugged in. they are, just not pulling vaccum Quote
z34_nut Posted October 13, 2004 Author Report Posted October 13, 2004 The Check valve is probably broken. $7 dealer part. ok, i'll look into that, wheres it located? Quote
digitaloutsider Posted October 13, 2004 Report Posted October 13, 2004 It's the thing all those vaccum lines connect to. It's probably got a crack in it somewhere. Quote
maybe2fast Posted October 13, 2004 Report Posted October 13, 2004 or the vacum ball is busted. the check valve is on the line that comes from the vacuum ball Quote
