john99gtp Posted October 10, 2004 Report Posted October 10, 2004 hey there. Lately, something weird has been going on with my engine not to sure what it is: Whenever I am at WOT (eg: drag racing), my car runs great until it shifts into third gear. It gets into third gear, and less then a second later, i lose boost and my RPMs decrease. Its really hard to describe, but today was my first day racing with a real boost gauge, and when it shifted into third, i was ~9psi, then it fell to about 4, and i lost power (not electrical, horsepower wise). It seemed to only do this after i put my Intense PCM in, but im not to sure i can blame that (unless the PCM limits the amount of boost, it might, but im a newb to these engines ) Im a newb to these engines, like i said above, so im not to sure where to point the finger at. If anyone has any idea, please let me know, and thanks in advanced. John Current mods: 3.5" pulley, Wizair CAI, Intense PCM, AutoLite 104's, and 180 TStat Quote
sl3196 Posted October 10, 2004 Report Posted October 10, 2004 Did you ever get a case learn done? Dunno if that would cause it or not. Something might be wrong with the boost bypass valve to. Quote
john99gtp Posted October 10, 2004 Author Report Posted October 10, 2004 Did you ever get a case learn done? Dunno if that would cause it or not. Something might be wrong with the boost bypass valve to. i messed around with the boost bypass, before i did any mods i pushed it down, but i reset it now (and somehow gained 1/10th in the 1/4 mile from doing that). If it will shift into third and hold, id be a happy man Quote
gpse_97 Posted October 10, 2004 Report Posted October 10, 2004 what spark plugs are you running? and list all your mods. your supercharger belt is most likely slipping. Quote
john99gtp Posted October 10, 2004 Author Report Posted October 10, 2004 mods r in sig im running a gatorback belt, and its tight and new im running autolite 104s if u cant see my sig.... as well as a 3.5 pulley, wizair CAI, INTENSE PCM, and 180TStat thats it Quote
gpse_97 Posted October 10, 2004 Report Posted October 10, 2004 hmm thats strange, did it happen right after you did the Intense PCM? what other mods did you do right before this happened? I doubt the PCM can limit boost, so I don't think that is the problem. Perhaps something with the Boost Bypass needs adjustment. Quote
sl3196 Posted October 10, 2004 Report Posted October 10, 2004 Did you get the case learn done? Might want to change your belt too, I've heard napa belts grip the best. Quote
manitcor Posted October 10, 2004 Report Posted October 10, 2004 this is an issue with the Intense PCM as I understand it. A friend of mine is having the excat same issue. The PCM allows boost for a certain amount of time. Intense sent him a new PCM but he has yet to test to see if it fixes the problem. Quote
gpse_97 Posted October 10, 2004 Report Posted October 10, 2004 this is an issue with the Intense PCM as I understand it. A friend of mine is having the excat same issue. The PCM allows boost for a certain amount of time. Intense sent him a new PCM but he has yet to test to see if it fixes the problem. I had no idea that the PCM can control boost like that. From what I seen the Boost Bypass is mechanically controlled. Quote
manitcor Posted October 10, 2004 Report Posted October 10, 2004 this is an issue with the Intense PCM as I understand it. A friend of mine is having the excat same issue. The PCM allows boost for a certain amount of time. Intense sent him a new PCM but he has yet to test to see if it fixes the problem. I had no idea that the PCM can control boost like that. From what I seen the Boost Bypass is mechanically controlled. Im not sure of the details of what is happening, I just know that he expierneced the same issue with the intense PCM and after troubleshooting determined that it is the PCM and intense sent him a new one. Quote
mfewtrail Posted October 11, 2004 Report Posted October 11, 2004 Did you ever get a case learn done? Dunno if that would cause it or not. Something might be wrong with the boost bypass valve to. i messed around with the boost bypass, before i did any mods i pushed it down, but i reset it now (and somehow gained 1/10th in the 1/4 mile from doing that). If it will shift into third and hold, id be a happy man You probably gained that tenth from the car building boost a bit later(giving you more traction off-the-line). Quote
