Smoke1991 Posted October 9, 2004 Report Posted October 9, 2004 well i fixed my alarm/remote start system. turned out whoever installed it b4 had 2 wires mix, the blue/white and the orange (accessory and ignition 1 i think) well the whole system works perfect but still, i dont get cluster power (guages do not work, and the climate controll does not work(all it blows is air, and when car gets warm, it blows warm air.) i followed justins wire diagram(thanks man alot) and its all wired up correctly. but i really want those to go on. I know i gota power an accessory wire, maybe there is 2 accessory wires, but i only have one right now, the diagram isint telling me about a second wire. any ideas people? i did have the info to get this working done on a peice of paper but that dissipeared :-( thanks for all the help Quote
Justin Posted October 9, 2004 Report Posted October 9, 2004 Do you need the astro diagrams again? I can send them again no problem. From my diagrams it just shows the two ignitions and the one accy. The blower motor should be running on the accy, so it shuts off when cranking to save amps. I'd take a test light and see if you're getting power to the orange vehicle wire. That's the accy. If you're getting power there then I don't know, it might run off of one of those ignitions I guess, but I doubt it. Check your blue/white to see if you're getting power there at all times when running with the starter. Quote
Smoke1991 Posted October 10, 2004 Author Report Posted October 10, 2004 nm looked up and got info purple white wire controlls cluster, and climate controlls uncluding everything needed for that gona tap into it tommorow thanks again for help. Quote
Smoke1991 Posted October 10, 2004 Author Report Posted October 10, 2004 it woked!!! im so happy, thanks justin Quote
