headlight switch
something is wrong with it. when i turned on my lights, they(the 2 on the switch and headlights)were flickering on and off. then they stayed off! :shock: every now and then when i'd turn em on, they will flicker and die. the guage dimmer still works and the only assumption is that i need a different switch.
after trying another switch and taking apart the original, they still dont work, and now my trunk button doesnt work. i'm starting to get fed up w/the little shit problems this thing is having. any help is appreciated.
hmmmmm fixed it! heard clicking from the driver's side fuse box, then i moved over to the aux post and was messing w/ my neon wire(it too was affected by the problem) and both would flicker. i popped the red cover off and discovered the 3/4" nut was loose!!!! :shock: :oops: tighten that bitch in the name of rick james!! and all is working again(knock on wood!!)
