Stealth Posted October 7, 2004 Report Posted October 7, 2004 when I put the turn signal right somtimes it doesnt work, I have to hold it. I just read that you can clean it then bend them or whatever, how to hell do you get the steering wheel off? Quote
Robby1870 Posted October 7, 2004 Report Posted October 7, 2004 with a steering wheel puller. But if you get a generic puller, odds are it only has standard bolts and our steering wheels need metric bolts Quote
digitaloutsider Posted October 7, 2004 Report Posted October 7, 2004 Get a steering wheel puller. Simple as hell. Either the switch is COMPLETELY BAD or the pins have become bent. Take it apart and bend the pins outward. You'll need a small Torx bit. I forget the size.. Quote
Stealth Posted October 7, 2004 Author Report Posted October 7, 2004 well the arms wobly, and all the wrtings worn out. but anyways wjere would I geta steering wheel puller? Quote
DiscoStudd Posted October 7, 2004 Report Posted October 7, 2004 What year is your car? If you have a 94-97 Cutty CLICK HERE . You can get a wheel puller from any auto parts store. The one I bought many years ago had a wide assortment of bolts included to remove all types of wheels. If you do have a 94-97, you'll also need a tool called a "Lock Spring Compressor" to get to the signal switch (I have a pic pointing it out on my "document.") Quote
Baddflash Posted October 7, 2004 Report Posted October 7, 2004 Try searching a bit I think you're the third Noob to ask this question this week. You can either try cleaning the old switch or if it's very worn out like your's sounds get a replacement one. Very simple to do shouldn't take you more than an hour if that long. Quote
