maybe2fast Posted October 3, 2004 Report Share Posted October 3, 2004 I talked to the guy that was probably the one that rebult my motor at the rebuilder company. I have a rebuilt 3.1 in my car with about 84,xxx on it and it runs great. I was talking to him and he said on the 3.1's they usually bore the cylinder walls out 20-40 over! tight! Then I asked about the heads I got new springs and rocker arms but the best part is the heads were shaved about 10 thousandths. tight! so bigger bore and alittle higher compression! the cams were either new or reground also so with the intake and gutted cat and the FFP chip, I'd say my little 3.1 is alright. Quote Link to comment Share on other sites More sharing options...
maybe2fast Posted October 4, 2004 Author Report Share Posted October 4, 2004 how much do you guys think my compression went up? Quote Link to comment Share on other sites More sharing options...
slick Posted October 4, 2004 Report Share Posted October 4, 2004 Not much probably. Do a compression check. Quote Link to comment Share on other sites More sharing options...
jeremy Posted October 4, 2004 Report Share Posted October 4, 2004 my doga$$ slow 3100 could still take ya..... Quote Link to comment Share on other sites More sharing options...
maybe2fast Posted October 4, 2004 Author Report Share Posted October 4, 2004 I bet not... Quote Link to comment Share on other sites More sharing options...
jeremy Posted October 4, 2004 Report Share Posted October 4, 2004 I bet not... I forgot you have the CF hood Quote Link to comment Share on other sites More sharing options...
maybe2fast Posted October 4, 2004 Author Report Share Posted October 4, 2004 thats the best you have? I am faster punk! Quote Link to comment Share on other sites More sharing options...
GP1138 Posted October 4, 2004 Report Share Posted October 4, 2004 I bet not... I forgot you have the CF hood You kidding?? That hood probably gives him like 30285230975 hp at the crank! You heard his tires squeal when he pulled out at Kensington... fucking scary if you ask me. Family sedan fuckin up the pavement here!! Quote Link to comment Share on other sites More sharing options...
Robby1870 Posted October 4, 2004 Report Share Posted October 4, 2004 how much do you guys think my compression went up? hmm....I bet its the same as stock, if not lower. Since you have 80 something thousand on it, the "shaved" heads only make up for whats' been lost in those 80K miles Quote Link to comment Share on other sites More sharing options...
Garrett8 Posted October 4, 2004 Report Share Posted October 4, 2004 i got a 108,800 on my stock little ole v6 i bet i could take ur car Quote Link to comment Share on other sites More sharing options...
jeremy Posted October 4, 2004 Report Share Posted October 4, 2004 i got a 108,800 on my stock little ole v6 i bet i could take ur car you should be proud that your DOHC can take a 3.1 pushrod.... Quote Link to comment Share on other sites More sharing options...
manitcor Posted October 4, 2004 Report Share Posted October 4, 2004 all this dumb dick swinging. lets see some slips Quote Link to comment Share on other sites More sharing options...
GPRACER Posted October 4, 2004 Report Share Posted October 4, 2004 all this dumb dick swinging. lets see some slips Too embarassing, all those 16.9-17.5 runs Quote Link to comment Share on other sites More sharing options...
94CutlassSLCoupe Posted October 4, 2004 Report Share Posted October 4, 2004 I got a slip with a stock 3100 cutty running a 17.07...beat that MPFI!!! Quote Link to comment Share on other sites More sharing options...
maybe2fast Posted October 4, 2004 Author Report Share Posted October 4, 2004 ok! Quote Link to comment Share on other sites More sharing options...
sonyman87 Posted October 4, 2004 Report Share Posted October 4, 2004 i will race ya pink slips? or are you afraid my 175000mile+ car will win Quote Link to comment Share on other sites More sharing options...
digitaloutsider Posted October 4, 2004 Report Share Posted October 4, 2004 ok! Good luck.. Quote Link to comment Share on other sites More sharing options...
DaveFromColorado Posted October 4, 2004 Report Share Posted October 4, 2004 if I remember correctly ... boring an engine to a larger can reduce compression ratios, and then shavin' the head could take it back up to normal, but I'd have to sit down and calculate all the crappy little number again.. I might be wrong, probably am - but I htink I'm right on this one. --Dave. Quote Link to comment Share on other sites More sharing options...
maybe2fast Posted October 4, 2004 Author Report Share Posted October 4, 2004 my appologies fellaz, I was just excited I had alittle work done to it. Quote Link to comment Share on other sites More sharing options...
jeremy Posted October 4, 2004 Report Share Posted October 4, 2004 my appologies fellaz, I was just excited I had alittle work done to it. so we aren't going to race??? Quote Link to comment Share on other sites More sharing options...
rudefyet Posted October 4, 2004 Report Share Posted October 4, 2004 once i get done with my iron duke swap...nobody on this board will be able to even touch my car... Quote Link to comment Share on other sites More sharing options...
White93z34 Posted October 4, 2004 Report Share Posted October 4, 2004 once i get done with my iron duke swap...nobody on this board will be able to even touch my car... DUDE, i'm iron duke swaping my car too, its gona be so fast... Quote Link to comment Share on other sites More sharing options...
sonyman87 Posted October 4, 2004 Report Share Posted October 4, 2004 Quote Link to comment Share on other sites More sharing options...
maybe2fast Posted October 4, 2004 Author Report Share Posted October 4, 2004 it will be more reliable Quote Link to comment Share on other sites More sharing options...
Aaron Posted October 5, 2004 Report Share Posted October 5, 2004 Wo a .020 over bore!!! God dang thats like, rubbing a piece of 1000 grit sandpaper over the bores once. Yah .020 isn't anything. Mine is .030, and that is a minor bore. As for the head deck, I forgot how much they trimmed mine up, but it bumped me to like 10.07:1 after they did the test. Also just how many "cams" do you have? Quote Link to comment Share on other sites More sharing options...
