Maverick Posted October 3, 2004 Report Posted October 3, 2004 It came on again, and won't turn off. I don't like seeing it. Any ideas on how to remove it with out removing the bulb? Quote
supreme_style21 Posted October 3, 2004 Report Posted October 3, 2004 A hammer. Fix the problem or it won't go away w/o removing the bulb. Quote
Maverick Posted October 3, 2004 Author Report Posted October 3, 2004 Darn it... I was afraid of that. Quote
DiscoStudd Posted October 3, 2004 Report Posted October 3, 2004 Well, I tightened down my auxilliary Positive battery terminal and the ABS light quit coming on . That was for a completely different reason, though (low voltage due to the cable being loose.) Maybe give it a try and see if it goes away, ya never know... Quote
skiiirt Posted October 4, 2004 Report Posted October 4, 2004 how about fixing the abs? perhaps a vaccum leak? that solved my abs problem Quote
93CutlassSupreme Posted October 4, 2004 Report Posted October 4, 2004 probably be easier to pull the bulb than fix the abs if my abs ever dies, i'll just rip the dash apart and pull the lightbulb Quote
supreme_style21 Posted October 4, 2004 Report Posted October 4, 2004 probably be easier to pull the bulb than fix the abs if my abs ever dies, i'll just rip the dash apart and pull the lightbulb Could simply be a sensor. Quote
93CutlassSupreme Posted October 4, 2004 Report Posted October 4, 2004 probably be easier to pull the bulb than fix the abs if my abs ever dies, i'll just rip the dash apart and pull the lightbulb Could simply be a sensor. or it could be a rear hub that = $ Quote
supreme_style21 Posted October 4, 2004 Report Posted October 4, 2004 probably be easier to pull the bulb than fix the abs if my abs ever dies, i'll just rip the dash apart and pull the lightbulb Could simply be a sensor. or it could be a rear hub that = $ The sensor comes out of the hub. Quote
93CutlassSupreme Posted October 4, 2004 Report Posted October 4, 2004 probably be easier to pull the bulb than fix the abs if my abs ever dies, i'll just rip the dash apart and pull the lightbulb Could simply be a sensor. or it could be a rear hub that = $ The sensor comes out of the hub. really? a few people here have told me the hub has to be changed. never looked it up in my manuals oh well, i hate abs anyways. Quote
supreme_style21 Posted October 4, 2004 Report Posted October 4, 2004 I hate ABS in the winter.. in the summer, it saves my tires. If it went out entirely, I probably wouldn't fix it. Quote
93CutlassSupreme Posted October 4, 2004 Report Posted October 4, 2004 I hate ABS in the winter.. in the summer, it saves my tires. If it went out entirely, I probably wouldn't fix it. it does blow in the winter. you just keep on going. abs isn't worth fixing if the repair isn't any sort of cheap and easy fix. Quote
DiscoStudd Posted October 4, 2004 Report Posted October 4, 2004 probably be easier to pull the bulb than fix the abs if my abs ever dies, i'll just rip the dash apart and pull the lightbulb I had a 92 LeSabre that I bought with the ABS non-functional. When I swapped dash clusters, I found the ABS idiot light had burned out ! There was no way in hell that I was ever going to have it fixed. My wife's Lumina never had ABS. Turns out ABS was optional in 96... Quote
WhiteOut Posted October 4, 2004 Report Posted October 4, 2004 Well, I tightened down my auxilliary Positive battery terminal and the ABS light quit coming on . That was for a completely different reason, though (low voltage due to the cable being loose.) Maybe give it a try and see if it goes away, ya never know... Ha!!! Mine did that too. That was the best fix ever. It took five minutes and got rid of multiple problems. Quote
DiscoStudd Posted October 4, 2004 Report Posted October 4, 2004 Well, I tightened down my auxilliary Positive battery terminal and the ABS light quit coming on . That was for a completely different reason, though (low voltage due to the cable being loose.) Maybe give it a try and see if it goes away, ya never know... Ha!!! Mine did that too. That was the best fix ever. It took five minutes and got rid of multiple problems. Has yours worked loose again after tightening it? Mine was starting to, so now I tighten it down every time I gas up. I'm thinking about putting another nut tightened down against the original one to keep it from working itself loose... Quote
