Heza Posted October 2, 2004 Report Posted October 2, 2004 ok...so i pulled the upper intake plenum and front cam cover off of my '96 to send to DykZ34 to polish. however, in the upper intake plenum there was a noticeable amount of oil just sitting there. what the hell would cause this? im almost partially worried about it. Quote
WhiteOut Posted October 2, 2004 Report Posted October 2, 2004 Are you sure its oil and not just carbon deposits in the intake? Unless you have monstrosterous amounts of blow by its unlikely to be oil, even then thats really odd. Quote
Heza Posted October 2, 2004 Author Report Posted October 2, 2004 Are you sure its oil and not just carbon deposits in the intake? Unless you have monstrosterous amounts of blow by its unlikely to be oil, even then thats really odd. when you can pour the shit out of all 6 intake ports and see it puddled in the head of the plenum, im sure its not carbon. Quote
DaveFromColorado Posted October 2, 2004 Report Posted October 2, 2004 too much blowby arround the rings, causing oil buildup in the pcv system pushing the oil up into the intake manifold. (that's the typical cause) or it just could be a bad pcv valve causing oil to slip past and into the intake. --Dave. Quote
Heza Posted October 2, 2004 Author Report Posted October 2, 2004 too much blowby arround the rings, causing oil buildup in the pcv system pushing the oil up into the intake manifold. (that's the typical cause) or it just could be a bad pcv valve causing oil to slip past and into the intake. --Dave. thanks Dave...ill go with PCV valve. that bitch was almost dripping when i pulled it out. hopefully that's the case. if its rings, im gonna get heated REEAAAAAAAL QUICK! Quote
DaveFromColorado Posted October 2, 2004 Report Posted October 2, 2004 if it's a fresh motor, the rings may not have seated yet. you can make a little catch can (I did) by using a bottle with a long stem, and a short stem, so it looks something like ... that'll keep the oil outta your intake. --Dave Quote
Heza Posted October 2, 2004 Author Report Posted October 2, 2004 if it's a fresh motor, the rings may not have seated yet. you can make a little catch can (I did) by using a bottle with a long stem, and a short stem, so it looks something like ... that'll keep the oil outta your intake. --Dave '96 aint that fresh. nice picture though....ill consider it. Quote
DaveFromColorado Posted October 2, 2004 Report Posted October 2, 2004 .. long road trips also seem to cause more blowby then normal ... --Dave. Quote
dohc v6 Posted October 2, 2004 Report Posted October 2, 2004 how much id dykz34 chrging to go the front vlve cover to polish Quote
Heza Posted October 2, 2004 Author Report Posted October 2, 2004 how much id dykz34 chrging to go the front vlve cover to polish depends on the amount of time. id ask him. Quote
White93z34 Posted October 2, 2004 Report Posted October 2, 2004 the only time i saw that was on a old turbo dodge i junked, it was so bad it spit oil right out into the airbox :shock: Quote
dohc v6 Posted October 2, 2004 Report Posted October 2, 2004 it just needs to be polished it is already sandblasted. Quote
94CutlassSLCoupe Posted October 2, 2004 Report Posted October 2, 2004 You may have an internal vaccum leak through the intake gasket, where it sucks oil through the lower intake gasket...if the intake gasket isn't fresh I would change it just to be safe Quote
Heza Posted October 2, 2004 Author Report Posted October 2, 2004 You may have an internal vaccum leak through the intake gasket, where it sucks oil through the lower intake gasket...if the intake gasket isn't fresh I would change it just to be safe yeah, there was oil on upper intake gasket too. the whole purpose was i am changing upper and lower gaskets out. but, since ill have big crap out of the way, im gonna detail my engine bay. you could be right about that. Quote
