Guest Gp crazy Posted October 1, 2004 Report Posted October 1, 2004 What is a "Front End Shaft Kit" for. in the picture it shows a bolt with a sleeve and two washers that are unique ? 8) Quote
bluegp Posted October 3, 2004 Report Posted October 3, 2004 What is a "Front End Shaft Kit" for. in the picture it shows a bolt with a sleeve and two washers that are unique ? 8) eh heh heh huh heh, he said shaft But seriously, when I hear "shaft kit", I think of the pieces that attach the front control arm to the frame (like on a rear wheel drive car). It's a shaft with bushings bolted to each end and a pair of holes in the center area. Quote
Justin Posted October 3, 2004 Report Posted October 3, 2004 That could be too, but I can't understand the "two washers that are unique" part. You don't adjust caster and camber with eccentric washers at the control arm. You do in the rear, but in the front you grind out the strut tower and adjust it there. Pics are definitely needed. Quote
Guest Gp crazy Posted October 11, 2004 Report Posted October 11, 2004 [img http://www.partsamerica.com/PartDetails.asp?SourceArea=&SourcePage=SEARCHRESULTS&MfrCode=TRW&MfrPartNumber=13239B&PartType=1290&PTSet=A IMG\] GO HERE ANY YOU WILL SEE WHAT IT LOOKS LIKE THANKS JEFF Quote
Justin Posted October 12, 2004 Report Posted October 12, 2004 That's to adjust camber/caster on the control arms of vehicles. Quote
