mysterious connectors.
i'm getting ready to fire my engine for the first time and went to double check everything, then found two mysterious connectors. one is under the ac compressor. it's a two wire connector, one green one black. the other is by the vacuum modulator for the tranny. it's a three wire plug, and looks like the tps plug. it's a 93 gp 3.1.
Guest BeausoleilRacing
A/C Compressor.
Lock up torque convertor solenoid?
i'm not even going to pretend i know what or where that is. i didn't see a female end anywhere for these two plugs to go into
I know the connector you're talking about. My girlfriend drove the Lumina to work (in 2nd gear, no less) or I'd go look and see. I know they go on the transmission.
the two wire plug doesn't plug into the compressor either. i checked.
Oil pressure sending switch?
the tps lookin one goes to the AC pressure switch, on the AC line on the drivers side that runs from the drier to the firewall.
the other sure sounds like the one that plugs on the compressor.
