Low Tech (cheap) diagnostic tools
Com On Guys and share your Low Cost/Tech Diagnostic Secrets here. I have one to get us started.
To check to see if your Fuel injectors are getting their signal you do not need an expensive diagnostic tool. Just get a 194 automotive bulb (very common at Wal Mart,probably one on your car right now) bend the metal wires and stick it in your injector connection, if it flashes when you crank the engine, you know you are getting a signal there and can go on to other things to check.
Anybody know of low cost ways to check the following
MAF/MAP sensors
IAC
Transmission Solenoids
Fuel Pumps
Crank/Cam Sensors
Ignition Modules
Coils
EGR
Relays
Fuel Systems
Ignition Systems
Cooling System
Leaking/Burnt Valves
etc.etc. etc. etc. etc.
Come On I know you got, now give em up.
Thanks
you can get a "noid" light that you can put on the wiring harness in place of the injectors to visually see if the signal is getting to that harness. they sell them real cheap at autozone/napa or other major parts stores.
--Dave.
A long ruler or piece of sanded wood to use as a stethoscope to hear how the engine is running. Now thats low tech.
A broomstick works fairly well.
You can test just about anything electrical with a multimeter.
Relays can also be tested with a jumper wire, circiuts with a test light.
Fuel pumps with a fuel pressure tester ($40) or listen for it running lol
Leaking/burnt valves: compression tester $50
Worn valve guides, worn rings, valve springs, vacuum leaks: vacuum guage $50
Some of those might not be very cheap, but hey they work.
The problem with only listening to a fuel pump is you can't diagnosis it if the pump is simply weak.....and not all the way out.
Actually, screw a voltmeter............test lights are the ultimate low budget tool........just becareful when you get to PCM work..........they are not high resistance machines such as a Fluke 87.
Using a paperclip is a constant for most older GMs.
A multimeter is your friend.
word.
