big loss of power??
My timinmg belt broke a while back and its finally fixed now. But it has had a real big loss of power and take off. it seems that when you push the gas tot ake off. it doesnt seem that the engine even starts to kick in until about 4000 RPMs. What could this be? I believe the engine has a vaccum leak, could this be the problem?
no don, the 3.4 is non interferance, at least the 93' is.
i believe some 95' and i think all 96' 3.4s were though.
sounds like something similar w/ a tbird i test drove......my mechanic said it would have cost around $500-$600 to fix IF they guessed right on the problem....mostly labor intensive and alot of it diagnostics.
sounds like the timing is off at first glance
but to cover other areas...
any noise in the top end?
also you said it may be vacuum....listen closely for any hissing sounds
